Random changes in eCart
Thread began 6/06/2014 11:50 am by Brendan | Last modified 6/10/2014 9:58 am by Jason Byrnes | 1383 views | 7 replies |
Brendan
I was just testing my shopping cart in live mode and found this issue.
I successfully added an item to the cart (add from recordset), proceeded to go through and complete checkout. I got an error on one of the field names for the orderdetails table. I went to the confirm page, updated the field, and uploaded to the server.
Went to run another test, and now my add to cart button isn't working.
Any ideas
Brendan
See below
Looks like it is working now, I was able to add 2 items to the cart. See attached screen shot
Brendan
I had to get it working, so started rebuilding pages. I started by rebuilding the page with the ATC, and only in steps. I found that when I added Server Validation, the form would work once, but if I clicked continue shopping it would no longer post to the cart. That included if I opened the page in another browser, and started from scratch.
I'm not sure if I'm doing something wrong in the validation behavior, but I'm not doing anything differently than I have done before.
I am not able to reproduce, in the attached screen shot i added the first item to the cart, used the continue shopping button and added the second item:
Brendan
This is a live site, I can't leave it in a non-working state.
Try this page...in PM
On that page, in the server validation, you have set it up to validate the cart columns.
you should use the Form element bindings instead.
