Add updateable quantity field to basket
Thread begun 6/26/2014 7:58 am by YellowCircleWeb | Last modified 6/26/2014 8:48 am by Jason Byrnes | 2073 views | 3 replies |
YellowCircleWeb
I have searched through the forums and not found an answer so far. I am using eCart 6 (latest version) and I want to add an updateable quantity field to the basket screen. I added the field using the 'Updateable text field' option from the eCart menu, but when I change the quantity and click update on the basket screen page reloads and the quantity goes back to 1. I have attached a copy of the basket page.
Any help is appreciated.
edit the code for the quantity field:
<input type="text" name="eCartSurface_Quantity_<?php echo $eCartSurface->DisplayIndex; ?>" value="<?php echo $eCartSurface->DisplayInfo("Quantity"); ?>" />
<input type="text" name="eCartSurface_Quantity_<?php echo $eCartSurface->DisplayInfo("WAUID"); ?>" id="eCartSurface_Quantity_<?php echo $eCartSurface->DisplayInfo("WAUID"); ?>" value="<?php echo $eCartSurface->DisplayInfo("Quantity"); ?>" onkeypress="waec_showUpdate('eCartSurface_Update_Quantity_<?php echo $eCartSurface->DisplayInfo("WAUID"); ?>',this);" />
i have logged a big in our system so that the next update will generate the correct code.
YellowCircleWeb
Thank you Jason, that's working now.
you're welcome.
