WA generated pages not deleting
Thread began 8/29/2014 9:12 am by Steve | Last modified 8/29/2014 10:12 am by Jason Byrnes | 2001 views | 10 replies |
Steve
Hello,
Starting a new Cart using the latest eCart 6 version.
Used the free eCommerce DB to get the basic tables in place.
Note the WA generated pages want to Insert and Update as Text for table products.ProductStock, ProductLive and ProductUnlimited. Easy to change but an update might help others.
The Delete button is not properly firing the Delete function. I've attached the file and a screen shot that shows that the delete dialog fires but that is as far as it gets.
Any ideas why?
products_results.php
Steve
Private message
This post has been deleted.
Steve
pm
ok, but what specific page should i be looking at, you give a general link to the admin section, but what should i do from there to reproduce?
Steve
WA Results page. products_results.php
Steve
you can also Click under store the List Products link
I Updated the results page to fix the problem, i removed the progress bar script:
<script src="../webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
which was conflicting with the modal window for some reason, I Will log this as a bug in our system.
Steve
Thanks.
I'm also seeing all the WA generated pages use the old MySQL connect rather than MySQLi... Hopefully you'll have some updater to run in the future as this looks like there will be a lot of hours updating pages just created if we want to migrate to future versions of PHP. I don't envy your tasks to update these extensions.
