Error message when I try to store data
Thread begun 9/28/2014 12:05 pm by Per-Olof | Last modified 3/24/2015 1:38 pm by Jason Byrnes | 7937 views | 11 replies |
Per-Olof
I get this error message when I try to store data
( ! ) Warning: call_user_func_array() expects parameter 1 to be a valid callback, first array member is not a valid class name or object in C:\wamp\www\Test-teamet\webassist\mysqli\queryobj.php on line 123
Call Stack
# Time Memory Function Location
1 0.0010 205832 {main}( ) ..\laguttagning_i.php:0
2 0.0140 329328 WA_MySQLi_Query->execute( ) ..\laguttagning_i.php:24
3 0.0140 332104 call_user_func_array:{C:\wamp\www\Test-teamet\webassist\mysqli\queryobj.php:123} ( ) ..\queryobj.php:123
( ! ) Fatal error: Call to a member function execute() on a non-object in C:\wamp\www\Test-teamet\webassist\mysqli\queryobj.php on line 124
Call Stack
This worked in the old MySQL.
What have I done wrong?
Per-Olof
this is caused by using numbers for column names which is not strictly allowed.
to work around the probelm, you will need to edit the code to add slant quotes (`) around the column name, for example, change:
$InsertQuery->bindColumn("1", "i", "".((isset($_POST["s1"]))?$_POST["s1"]:"")  ."", "WA_DEFAULT");
$InsertQuery->bindColumn("`1`", "i", "".((isset($_POST["s1"]))?$_POST["s1"]:"")  ."", "WA_DEFAULT");
and do that for each column that uses a number for it's name.
Per-Olof
Thanks but
Is not it easier to change in the table, column 1 becomes s1, 2 becomes s2 and so on.
there will be less problems in the future if one forgets.
yes, that would be easier.
stephen287384
stephen287384
PM
see pm
