An appropriate representation of the requested resource
Thread begun 10/02/2014 3:33 pm by nickj | Last modified 10/13/2014 8:00 am by Jason Byrnes | 7699 views | 28 replies |
nickj
I have replaced the old recordset with a MYSQLi recordset and now get this error which I can't understand.
An appropriate representation of the requested resource /admin/Project/ETFproject_prj_update.php could not be found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
I send the ftp info yesterday so I think you have access to the files. Also the check boxes are wrapping despite adding the width to the columns in the CSSS
Nick
I dont see your thread form yesterday, please include the ftp info in this thread or a link to the other thread so I don't have to track it down.
nickj
Thanks for the quick response
You removed the MySQL recordset from the page, and replaced it with a MySQLi recordset, however, there where a number of places where the old MySQL recordset was being referenced causing errors in the page.
I replaced those instances with the code for the MySQLi recordset to fix the problem.
nickj
Thanks, it would be useful to have a tutorial discussing how to transition to MYSQLi, it's net very intuitive for those of us who just tweek code rather than living it it:).
Once again thanks for your fast support.
Nick
nickj
So the other question of the check boxes wrapping. I edited the CSS to set the column width but the div is still not fitting! where am I going wrong?
in the CSS edit the form.Cool_Default span.radioFieldGroup_Wide selector and add float: right; and width: 400px;
for now, there really is not a transition. The data assist insert and update behaviors do not support MySQLi, so there is no need to convert the recordets on data assist pages.
We are in the process of upgrading data bridge to be compatible with MySQLi so that it will generate MySQLi code natively, until that upgrade, there is not much to be gained by edit the recordsets on data assist generated pages to use MySQLi
nickj
Thanks Jason
you're welcome.
nickj
No luck. Please see attached I added the width and float.
