DW CC 2014.1 No longer sees Security Assist Server Behaviors
Thread began 11/12/2014 1:06 pm by Tony | Last modified 11/13/2014 6:44 am by Jason Byrnes | 1176 views | 3 replies |
Tony
I have installed all of the new extensions for cc 2014.1 and now have a problem with sdome server behaviors. I don't if there are others yet, but I have some login forms that I built with the previous version of Databridge that are now not showing up in either cc 2014.1 or DW 6, which I keep around just incase I have this kind of issue.
It seems that the authentication behaviors don't show up in the server behaviors panel. Any thoughts?
Thanks,
Tony
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
in some cases, you may need to restart the OS, then delete the cache file.
Tony
Worked!
Thanks Jason.....worked like a charm!
Tony
you're welcome
