ISSSUE WITH ECART AND BLANK PAGE
Thread begun 11/13/2014 8:51 am by Solis Web Design And Hosting | Last modified 5/27/2020 3:21 am by nevastech | 9410 views | 11 replies |
We are facing an issue that after we checkout and select the merchant paypal direct as payment and enter the information the cart processes our credit card but it shows a blank page right after we enter the credit card info and we submit even though the credit card gets charged
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
here is the error i got
Warning: PP_DirectPayment_Post(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EST/-5.0/no DST' instead in /home/hsphere/local/home/allstartrainers/allstartrainers.com/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php on line 118 Notice: Undefined variable: billingAgreements in /home/hsphere/local/home/allstartrainers/allstartrainers.com/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php on line 118 Warning: PP_DirectPayment_Post(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EST/-5.0/no DST' instead in /home/hsphere/local/home/allstartrainers/allstartrainers.com/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php on line 281 Notice: Undefined variable: billingAgreements in /home/hsphere/local/home/allstartrainers/allstartrainers.com/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php on line 281 Warning: main(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EST/-5.0/no DST' instead in /home/hsphere/local/home/allstartrainers/allstartrainers.com/confirm.php on line 305 Fatal error: Call to undefined function WA_eCDB_ConvertNumber() in /home/hsphere/local/home/allstartrainers/allstartrainers.com/confirm.php on line 305
This is a php server issue.
The host should be able to update the php.ini file for you to set the default timezone to prevent that error from occurring. It happens if the default time zone is not set in the php.ini.
alternately, you can add the following code to the page to set the time zone:
date_default_timezone_set('America/New_York');
The list of valid timezones is here...
http://www.php.net/manual/en/timezones.php
it is best to have the host fix it in the php.ini file though so you don't keep running into it in other places.
added code to see if that's the issue and it still gave this error
Notice: Undefined variable: billingAgreements in /home/hsphere/local/home/allstartrainers/allstartrainers.com/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php on line 121 Notice: Undefined variable: billingAgreements in /home/hsphere/local/home/allstartrainers/allstartrainers.com/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php on line 284 Fatal error: Call to undefined function WA_eCDB_ConvertNumber() in /home/hsphere/local/home/allstartrainers/allstartrainers.com/confirm.php on line 312
Information is in private message
I Updated the WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php and confirm.php pages, the errors should be fixed.
still getting error..
Notice: Undefined variable: billingAgreements in /home/hsphere/local/home/allstartrainers/allstartrainers.com/WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php on line 121 Warning: require(wa_receipt_12.php): failed to open stream: No such file or directory in /home/hsphere/local/home/allstartrainers/allstartrainers.com/webassist/email/mailformatting_php.php on line 151 Warning: require(wa_receipt_12.php): failed to open stream: No such file or directory in /home/hsphere/local/home/allstartrainers/allstartrainers.com/webassist/email/mailformatting_php.php on line 151 Fatal error: require(): Failed opening required 'wa_receipt_12.php' (include_path='.:/hsphere/shared/php53/lib/php') in /home/hsphere/local/home/allstartrainers/allstartrainers.com/webassist/email/mailformatting_php.php on line 151
Ok, i updated the WA_eCart/Adv_CO_Scripts/PP_DirectPayment_PHP.php file again, should be fixed now.
