defective file jquery-blockui-formprocessing js
Thread begun 3/05/2015 11:24 am by JBWebWorks | Last modified 10/27/2015 10:36 am by Ray Borduin | 4005 views | 7 replies |
JBWebWorks
I have newest version of databridge and design extender and before i had those installed i saw in a previous forum thread that the jquery-blockui-formprocessing.js file was defective and a new one was posted in a zip file. So every time i added progress bar to a form, I had to replace the js file to get the progress bar to work
With the newest version i didn't have to replace the jquery-blockui-formprocessing.js file, but it has started again for some reason?
that file is also in eCart, could be that you installed eCart recently and over wrote the one in the configuration folder.
locate the users configuration folder and add the good version of the jquery-blockui-formprocessing.js file to the following folder:
Configuration/Shared/WebAssist/DigitalFilePro/Helpers
JBWebWorks
Thanks Jason,
That worked. I hadn't installed anything since buying Design Extender so not sure what i did? But I removed the progress bar from a form and then deleted the jquery file and then added the progress bar back and the working jquery file was installed. And it works fine.
Thanks again for your help.
you're welcome.
DarylBeta Tester
Hi JBWebWorks
Do you have a link to the newest version of jquery-blockui-formprocessing.js as I am getting an error with this file after adding a progress bar also.
Here is the latest version I have.
DarylBeta Tester
Thanks Ray, unfortunately that didn't help.
The error that I am getting is:
unreachable code after return statement1 jquery-blockui-formprocessing.js:19:13091
Can you post a url where I can view the problem? I'll need to look at the page.
