map not showing
Thread begun 3/10/2015 8:45 am by Jamie | Last modified 3/12/2015 9:14 am by Jason Byrnes | 3257 views | 5 replies |
Jamie
map not showing
Hey Jason
Have spent a couple of hours trying to figure out why the map is not showing on this page: http://clients.motley.co.uk/ranmoor/contact.php - it should be showing where the grey box is shown below the form.
Jamie
It looks like the page is missing the script at the bottom of the page that actually draws the map.
It should be something like:
<script type="text/javascript" src="webassist/google_javascript/wagmp_maps.js">/*wagmp*/</script>
Jamie
hhhhmm my bad....
cheers Ray... I must have removed it when I was trying to get it to work. Put it back and its now 'working'
There is still an issue in that the zoom and streetview icons (see http://prntscr.com/6fe9ca) are not being shown... I have tried redoing the map a couple of times and get the same result.
in your css:
http://clients.motley.co.uk/ranmoor/css/coffeegrinder.min.css
you have the following img definition:
img {
border: 0 none;
height: auto;
max-width: 100%;
vertical-align: middle;
width: auto;
the max-width: 100%; is causing the issue. that needs to be removed.
Jamie
thats a shame as thats what gives the hero images their responsiveness.... any thoughts on a possible workaround to retain that and still be able to use the maps?
create a class for the images and add the max-width property to the class.
