While exicutiung timer in WADA_Main.htm, the following Javascript error(s) occurred. At line....Configuration:Commands:WADA_Main.js" wa.datassist.settings.pages.detail_page has no properties.
Thread begun 3/11/2015 5:39 pm by nickj | Last modified 3/16/2015 1:34 pm by Jason Byrnes | 7940 views | 17 replies |
nickj
While exicuting timer in WADA_Main.htm, the following Javascript error(s) occurred. At line....Configuration:Commands:WADA_Main.js" wa.datassist.settings.pages.detail_page has no properties.
I've deleted everything! preferences for DW and configuration files, five times, and still get this error every time I try to build a very simple form using DataAssist Pages behavior. Please help me get this to work. See attachment:
RAll56117681
I'm aving exactly the same problem. Has started happening ever since upgraded to Data Bridge 1.2.2
nickj
Dreamweaver CC removed HELP I need to get CS6 to work again
SO, using MAC 10.10.2 I un-installed Dreamweaver CC (total failure with different errors every time) and removed the preference files and configuration files for both CS6 and CC. Re-installed CS6 and removed all extensions. downloaded DataBridge 122 did teh 1-2-3 and CS6 crashed. Restarted and activated DataBridge. Restarted again and tried to run DataAssist Pages wizard and dreamweaver gave me error 1(see attachment) and then error 2(see attachment). Removed CS6 Preferences and configuration files and restarted CS6.Restarted extension manager (empty) and installed Databridge 122. Installed 1-2-3, activated and it crashes.
Dreamweaver remembered my sites and opened with the last site I worked in. This is the third day I've spent trying to build a simple entry form, pro bono and I have to succeed.
Questions:
1. Obviously there are more corrupted files storing my history, where are they?
2. How do I get ride of the errors and get CS6 to work?
Was I supposed to remove CS6 before installing DW CC?
try recreating the users configuration folder.
this is the folder that you find the DW Cache file in:
after you rename the configuration folder, open Dreamweaver to recreate it, then close Dreamweaver. Now open the extension manager, remove all the extensions, then install them again.
nickj
I removed the user configuration file (/users/[username]/Library/Application Support/Adobe/Dreamweaver (version)/en_US/Configuration/) every time and removed the Adobe Dreamweaver CS6 Prefs.
removed the Databridge extension, started and closed CS6, re-installed the extension.
IF I can't go back to CS6 should I remove it and all config. and pref. files before reloading DW CC?
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
nickj
SKype nickjewett I'm in Kingston WA. I'll be at my computer all day, really stuck here so I appreciate you connecting. also my phone number is 360-271-8659
Ray has done a hot fix build for this issue.
uninstall DB 122 then reinstall it, m,make sure the web assist installer runs when you start Dreamweaver and that should install the fix.
nickj
Fresh everything: and still get the error. see attachment
I have passed your contact info on to Ray and asked him to contact you.
