retain some session values after checkout
Thread begun 3/24/2015 1:03 pm by CraigR | Last modified 3/26/2015 9:48 am by Jason Byrnes | 2259 views | 5 replies |
CraigRBeta Tester
I have a checkout success page with a standard code block at the end to destroy the session values
//initialize the session
session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (isset($_COOKIE[session_name()])) {
setcookie(session_name(), '', time()-42000, '/');
// regenerate the session id
//http://www.webassist.com/forums/showthread.php?p=105930#post105930
session_regenerate_id();
// Finally, destroy the session.
@session_destroy();//This will also clear the session cookie which forces a new session ID to be generated.
session_start();
Most pages on this internal site are admin access only, so I want to retain the session values created when the admin user (or superadmin) logs in, via admin_cms/user_login.php
what i have tried to do is simply store the session values as php variables before destroying the session, then reset the session values afterwards, but it doesn't seem to be working,
session_start();
//store login session values before destroying session
$superadminlogin = $_SESSION["SuperAdminLogin"];
$adminlogin = $_SESSION["AdminLogin"];
$userid = $_SESSION['UserID'];
$usergroupid = $_SESSION['UserGroupID'];
$contentgroup = $_SESSION['ContentGroup'];
$userfname = $_SESSION['UserFirstName'];
$userlname = $_SESSION['UserLastName'];
session_start();
//restore login session values
$_SESSION["SuperAdminLogin"] = $superadminlogin;
$_SESSION["AdminLogin"] = $adminlogin;
$_SESSION["UserID"] = $userid;
$_SESSION["UserGroupID"] = $usergroupid;
$_SESSION["ContentGroup"] = $contentgroup;
$_SESSION["UserFirstName"] = $userfname;
$_SESSION["UserLastName"] = $userlname;
<?php var_dump
($_SESSION);?>
that should work. I'll need to troubleshoot directly, see the private message section.
CraigRBeta Tester
PM
i fixed this by adding:
after reseting the sessions.
CraigRBeta Tester
Awesome, thanks Jason
you're welcome.
