data assist update multiple recorsd
Thread begun 4/14/2015 1:24 am by QuiruNet | Last modified 4/16/2015 12:11 pm by Ray Borduin | 2277 views | 5 replies |
QuiruNet
I have a gallery, where my client must select many images by clicking a check box, but the thing is, when the client ckeck, the page update, do you know if y can make it with data assits update multiple records...choose all images at the same time and then click update all.
thanks.
Yes, that should be possible with Data Bridge and the multiple update and/or insert.
QuiruNet
info error
i used the data assist update multiple recorsd, with a check box, but you see in the fallow link, in the very end of the images, if you check the image, and then you to the begining of the page and click "actualizar selección", doen´t update.
http://lapostboda.es/_clientes/seleccionar2.php?gallery_id=586&kt_login_id=368
this lik is open
You have to give your checkbox a value... I added value="1" to your checkbox and it appears to be working now.
QuiruNet
info
I added a value of 1, but doesnt work, if you go to the end of the page of images and select the las one, and click the check box, and update doesnt change the status.
This is because your form has more than the default 1000 fields allowed in a php form post. The first 1000 work properly, but the last one will not.
To address this you can change the value in your php.ini file and increase the amount listed under: max_input_vars
