Help using mysqli in dynamic parent, child dropdowns.
Thread begun 7/20/2015 8:49 am by Dave W | Last modified 7/20/2015 9:12 pm by Ray Borduin | 4625 views | 6 replies |
Dave W
I am still having problems converting the dynamic dropdown extension to use with MySqli.
I think I am almost there but the child menu is still not populating. Can you help please.
I have attached the page involved in a PM.
Unfortunatly though my knowledge of MySql is quite good, I am having problems with MySQLi.:-)
Do you have a live url where I can see it in action? I don't see the problem offhand, but if I had a working page to look at I'd have more to go on.
Dave W
Hello again Ray,
Good of you to help. I have set this page up on the server in the PM. The main site is in MySql so I had add the scripting and folders for MySqli to this folder for it to work.
Update line 18:
$getItems = new WA_MySQLi_RS("getItems",$dbCute,1);
should be:
$getItems = new WA_MySQLi_RS("getItems",$dbCute,0);
The recordset was only returning one row, that might be the only problem.
Dave W
Hi Ray,
Thanks for that but it still doesn't work.
The code was origially produced by the dynamic dropdown extension, then copied over and upgraded to MySqli, so I can't really see why it shouldn't work, but then again, I do lack experience with MySqli.
Please attach a current copy of the page... It appears the line I referenced hasn't been updated on the live page yet.
Also do a find/replace and find:
getItems_WAJA
replace it with:
undefined_WAJA
It appears that since Dreamweaver couldn't find the recordset it may have updated the code to use "undefined" instead of the recordset name, but it is still the recordset name in the code you updated manually. I think by updating it to just use "undefined" you won't have to worry about dreamweaver switching it back again.
Dave W
Hello Ray,
Replacing getItems_WAJA with undefined_WAJA seems to have done the trick. It works fine now as you can see on the live page I sent you.
Thank you so much, I have spent the whole weekend looking for that problem.
You guys really are the bees knees!!
Hope this will help when the dynamic dropdown is updated.
