Progress bar just keeps spinning, form never submits
Thread begun 10/23/2015 7:12 am by gstoyle396649 | Last modified 10/23/2015 3:37 pm by Ray Borduin | 5037 views | 7 replies |
gstoyle396649
I'm trying to put a progress bar on a simple login form (using your mysqli user authentication).
When the form is submitted the progress bar appears, but it never goes away and the form is not submitted.
I've tried the same on a few other forms and the same thing happens.
If you give me the url to the page I can take a look.
gstoyle396649
I'm working on localhost so that's not possible at the moment I'm afraid.
However, all I have done is apply the progress bar to a form as I've done many times.
The code on the page is very simple - the only difference being it uses the mysqli extension. This is the first project I've done which uses that...and is the first one where the progress bar doesn't work.
I can provide the code...
<?php require_once('Connections/conn.php'); ?>
<?php require_once('webassist/mysqli/authentication.php'); ?>
@session_start();
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$_SESSION["project"] = "".((isset($_POST["project"]))?$_POST["project"]:"") ."";
$Authenticate = new WA_MySQLi_Auth($conn);
$Authenticate->Action = "authenticate";
$Authenticate->Name = "User";
$Authenticate->Table = "sms_projects";
$Authenticate->addFilter("login", "=", "s", "".((isset($_POST["username"]))?$_POST["username"]:"") ."");
$Authenticate->addFilter("pwd", "=", "s", "".((isset($_POST["password"]))?$_POST["password"]:"") ."");
$Authenticate->storeResult("login", "username");
$Authenticate->AutoReturn = false;
$SuccessRedirect = "index.php";
$FailedRedirect = "login.php";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
<!doctype html>
<html>
<head>
<script src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<meta charset="utf-8">
<link rel="stylesheet" type="text/css" href="assets/css/style.css">
</head>
<body>
<fieldset>
<legend>
<h2>Login</h2>
</legend>
<div id="form1_ProgressWrapper">
<form action="" method="post" name="form1" id="form1">
<table width="100%" border="0" cellspacing="0" cellpadding="4">
<tbody>
<tr>
<td width="12%">Project:</td>
<td width="88%"><p>
<label>
<input type="radio" name="project" value="cerp" id="project_0">
CERP</label>
<label>
<input type="radio" name="project" value="seb" id="project_1">
Sebastian River</label>
<br>
</p></td>
</tr>
<tr>
<td>Username:</td>
<td><input type="text" name="username" id="username"></td>
</tr>
<tr>
<td>Password:</td>
<td><input type="password" name="password" id="password"></td>
</tr>
<tr>
<td>&nbsp;</td>
<td><input type="submit" name="submit" id="submit" value="Login"></td>
</tr>
</tbody>
</table>
</form>
</div>
</div>
</fieldset>
<div id="form1_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('form1', 'form1_ProgressMessageWrapper', WADFP_Theme_Options['Bar:CaboSunset']);
</script>
<div id="form1_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="webassist/progress_bar/images/cabo-bar.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
</div>
</body>
</html>
It has nothing to do with the server side code.
It looks like you have this line of code repeated:
that may be the issue.
gstoyle396649
I'm not sure how that line of code got repeated.
However, I have removed it and the problem still exists. The progress bar appears but the form doesn't submit - I have to close the tab to clear it.
Here is the code without the repeated line...
@session_start();
<!doctype html>
<html>
<head>
</head>
<body>
<fieldset>
<legend>
<h2>Login</h2>
</legend>
<tbody>
<tr>
<td width="88%"><p>
<label>
CERP</label>
<label>
<br>
</p></td>
</tr>
<tr>
<td>Username:</td>
</tr>
<tr>
<td>Password:</td>
</tr>
<tr>
<td>&nbsp;</td>
</tr>
</tbody>
</table>
</form>
</div>
</fieldset>
</script>
</div>
</div>
</body>
</html>
The issue is that you have an id of your form button set to "submit", which is a reserved name in forms since forms have a .submit() method. Just change the button ID and it should fix the problem.
gstoyle396649
OK that's done it, thanks.
Do you specify that anywhere in the documentation?
We don't document html and javascript in general. Here is a list of reserved words in html and javascript:
http://www.w3schools.com/js/js_reserved.asp
you should avoid all of these in IDs and variable names. You can see that submit is on the list. This isn't just true for our extensions it is for building web pages in general.
