Problem with Dynamic Lists
Thread began 3/30/2009 8:49 pm by tomm | Last modified 4/02/2009 6:46 pm by tomm | 3025 views | 3 replies |
tomm
I have been trying to set up a set of parent/child dynamic lists with Dynamic Dropdowns and I don't think the extension is working.
I have two very simple tables as follows:
Table 1: Sport
Field: id(integer)
Field: SportName(varchar)
This table is populated with one record:
SportName = Volleyball
Table 2: Positions
Field: id(integer)
Field: PositionName(varchar)
Field: Sport(varchar)
This table is populated with 3 records:
PositionName = Setter
Sport = Volleyball
PositionName = Outside Hitter
Sport = Volleyball
PositionName = Blocker
Sport = Volleyball
What I want to do is have someone select a Sport from a dynamic menu populated from the Sport recordset and then select a Position from a dynamic menu populated with values from the Positions recordset based on the Sport that was selected.
Seems like an ideal use for Dynamic Dropdowns.... but I can't get it to work. I've followed the instructions in the WebAssist help doc section "Populating a Child List from a Parent List" and have created the Dynamic Array using the Server Behaviors panel. But when I try to do the next step "Populate List from Array", the "WA Dynamic Dropdowns > Populate List From Array" is not available in the Server Behaviors panel (see attached screenshot).
What is going wrong here? Am I doing this procedure correctly?
TM
It should be possible, so you must be overlooking something. I can't tell from your description what that might be.
It is a "Behavior" and not a "Server Behavior"... after reading more carefully and looking at the screen I figured out your confusion. Highlight the parent list and go to the "Behaviors" window.
tomm
Found it where you said and things are working great!
Thanks,
TM
