Error when trying to use CSS Form Builder
Thread begun 9/02/2009 1:16 am by ftg.peters379769 | Last modified 9/04/2009 2:17 pm by Eric Mittman | 2970 views | 4 replies |
ftg.peters379769
When I try to use the CSS Form Builder I get an error concerning the wafb_serial.htm and the shared_ser_mactivation.js files. I have activated using the menu: Insert/Webassist/CSS Form Builder/Client Validation. So I have activated CSS Form Builder but I can't use it when I try to create a new CSS Form ! The path in the attached jpg file doesn't excist. The htm and js files are on C:\Document and settings\....\library and not on drive D: (which is the installation path of Dreamweaver CS4 on Windows XP SP3 system). I've installed and can use all the extensions of WA Super Suite without any problems (except CSS Form Builder). Reinstallation doesn't work either. Who can help me out ?
This could potentially be a problem with the cache file but I kinda doubt it. To be certain though please give this a try and let us know if the issue persists. If it does then I will open a ticket for you and try to get this to our engineers to look into further.
In this thread are some good instructions for deleting the cache file to get around any issues that it may be causing you.
showthread.php?t=1589
ftg.peters379769
RE: Error when trying to use CSS Form Builder
I've deleted the file winfilecache-55DB99DB.dat which was located at C:\Documents and Settings\...\DreamweaverCS4\en_US\Configuration but the problem still exists. What can I do next ? Please help me out.
ftg.peters379769
Problems with using CSS Form Builder
Is there no one who suffered the same problem or has a solution ? Does someone at Webassist know how to solve this, because I can't use CSS Form Builder this way ?!
I have opened a ticket for you on this issue. I have posted a possible solution for you there, please login to WebAssist.com and visit your support history to update the ticket and let us know if this resolves the problem for you.
