Email Form Not Sending Emails
Thread begun 2/08/2016 7:00 am by salaroche | Last modified 2/12/2016 10:30 am by Ray Borduin | 6815 views | 28 replies |
salaroche
Hi:
I have created an email form that is supposed to send emails using the email addresses stored in a DB, but the form is not sending any emails. In the past I have successfully created similar email pages that still work today, but somehow I haven't managed to make this one work.
Please see private message below.
I can't seem to connect with your FTP information provided. Please confirm there are no typos or IP restrictions and I'll try again.
salaroche
Ray:
I'm using FileZilla and I just connected again with no problem using the exact information I gave you.
You have your from address set to:"Accounts Department"
You will need to use an email address in the FROM field or your SMTP server won't send the email.
salaroche
Ray:
I entered a valid Email Address in the FROM field but I'm still not getting any emails in my inbox. In consulting my Hosting service I also tried different SMTP parameters but still nothing. I also tried sending emails from another Website of mine, salaroche.com, that uses WebAssist and that one works fine. This looks like I still haven't configured this one well.
Would this mean that the TO field is not configured well? It's supposed to be drawing email addresses from the users table through the recordset "teachEmails".
It appears it could be an issue with your hosting provider.
I tried a simple email script to see if it sends:
$to
= 'ray@webassist.com';
$subject = 'the subject';
$message = 'hello';
$headers = 'From: ray@webassist.com' . "\r\n" .
'Reply-To: ray@webassist.com' . "\r\n" .
'X-Mailer: PHP/' . phpversion();
mail($to, $subject, $message, $headers);
and I'm not getting an email from that either. Another technique that works on some servers is:
mail
('ray@webassist.com', 'the subject', 'the message', null,
'-fray@webassist.com');
but that isn't working either.
This points to configuration issues with your hosting. I'd contact them with these two scripts... until one of them works, our email script won't work either.
salaroche
That's really curious because another Website of mine that uses a WebAssist email form is sending emails perfectly well. You can try it, if you wish, by going to www.salaroche.com > Contact and send me an email. I'm sure to get it.
I'll still contact my Hosting service in Ohio and consult with them again.
Probably the sample script I sent you would send from that server as well. That evidence is consistent with my hypothesis that there is nothing actually wrong with your code.
I put up identical test pages on both sites... test them and see. You will have to change the TO address to yours, but I get the one on www.salaroche.com but not the one on payslip.salaroche.com.
The pages are exactly identical.
salaroche
Ray:
It turns out that the company server where the program will finally be installed does not allow for sending emails outside its network. I'm trying to go around that impediment by linking the program to a Gmail account where there will be a pre-formatted email form that the chief accountant may send to the interested parties.
The small obstacle I have found is that the link opens the Gmail window in the same tab of the program (payslip) page.
Is there any code that I could add to the link so that the Gmail page opens in a separate tab?
I'm not sure how you are linking to it, but usually the answer is to add: target="_blank" in the link.
