Cannot modify header information
Thread begun 3/04/2016 2:40 pm by Kumel | Last modified 3/07/2016 11:41 am by Ray Borduin | 1588 views | 3 replies |
Kumel
Frequently getting this error all time in update page & also in delete category page.
1stly add-product.php after adding product doesn't redirect page. Just this error comes up.
Warning: Cannot modify header information - headers already sent by (output started at /home/content/39/10368039/html/**/ft/admin/add-product.php:43) in /home/content/39/10368039/html/webgen/ft/admin/add-product.php on line 129
But product is getting added.
Delete-product.php also receiving after submitting form.
edit-product, & many other pages.
This error is after adding to server online.
Most of the errors are: header("Location: ".$WA_redirectURL);
I tried changing unicode check & unchecked as well. still error is appearing.
This is because of blank lines and comments you have between your php code. Those will have to be removed.
Look at the first line when you get these errors, where it says "output started at". That is where they are caused... so for this one /add-product.php line 43
You will see you have comments and blank lines between your php code above the <html> tag between the php tags: ?><?php
This is not allowed and will cause header errors when you try to redirect to another page in code below it.
Kumel
Why are comments causing problem? i have used so many comments in other pages it didnt cause any problem as such.
You have to use php comments above the <html> tag... html comments need to be within the HTML.
PHP comments look like this:
<?php // This is my comment ?>
