form multi select list insert records
Thread begun 6/06/2016 12:34 pm by Christopher West | Last modified 2/20/2019 10:52 am by Ray Borduin | 13133 views | 52 replies |
Hi Ray, as discussed recently on a premiere ticket I wanted to look at using some code I found to allow client to do a multi select from a drop down and then save each into records.
So I need to somehow loop through each item that's selected in the multi select list on the form and perform an insert.
Also inside the multi select list I have grouped the sub-categories (child) into their corresponding parent category (at the moment its only displaying the ID value rather than the name, so I need to tweak the recordset that can do this (since the same table is storing both parent and child).
So I wonder upon form submit, what would the process be to do a multi insert for each value in the multi select list? I wanted to try myself before we use up the remaining support ticket I purchase.
I am providing the code and screenshot as reference.
<select style="width: 260px;" multiple="" class="chosen-select">
while(!$rsCategory->atEnd()) { //dyn select
if ("".($rsCategory->getColumnVal("CategoryParentID"))  ."" != "0") {  // WebAssist Show If
?><optgroup label="<?php echo($rsCategory->getColumnVal("CategoryParentID")); ?>">
// ("".($rsCategory->getColumnVal("CategoryParentID"))  ."" != "0")
<option value="<?php echo($rsCategory->getColumnVal("CategoryID")); ?>"><?php echo($rsCategory->getColumnVal("CategoryName")); ?></option>
</optgroup>
  $rsCategory
->moveNext();
//dyn select
$rsCategory->moveFirst();
                              </select>
Chris
Usually you would name your select list with brackets like:
<select name="selectedCats[]"
That way when submitted it would create an array from the values in the $_POST['selectedCats']. Then you could loop through that array doing your inserts.
Hi, so an array is created by add [] then how would I implement the loop for the insert record?
You could use a FOR loop to loop on the array and wrap it around the insert code.
could you provide some sample code please?
Chris
for ($x=0$x<sizeof($_POST['selectedCats']); $x++;) {
// insert to database code here with binding set to:
<?php echo($_POST['selectedCats'][$x]); ?>
Hi, Its almost working. it does insert the number of items I have selected. however, what its doing is inserted the same ID for all entries. After my test if I select all categories from the list, the ID which is being written to the table is the very first ID from those that I select.
For example is my database table consider of:
CategoryID
6
7
8
9
10
and if I select all the above in my multi-select list then it will create 5 records in the catalog table BUT all with ID 6 being stored.
Here is the code for the insert and the code for the html form:
Chris
for ($x=0$x<sizeof($_POST['selectedCats']); $x++) {
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) {
$InsertQuery = new WA_MySQLi_Query($ecartdb);
$InsertQuery->Action "insert";
$InsertQuery->Table "`catalog`";
$InsertQuery->bindColumn("CatalogCategoryID""i""".((isset($_POST["selectedCats"]))?implode(",",$_POST["selectedCats"]):"")  ."""WA_DEFAULT");
$InsertQuery->bindColumn("CatalogProductID""i""".$_SESSION['ProductID']  ."""WA_DEFAULT");
$InsertQuery->saveInSession("CatalogID");
$InsertQuery->execute();
$InsertGoTo "product-manage.php";
  if (
function_exists("rel2abs")) $InsertGoTo $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
<select name="selectedCats[]" style="width: 260px;" multiple="" class="chosen-select">
          <optgroup label="<?php echo($rsCategory->getColumnVal("CategoryID")); ?>">
          </optgroup>
  $rsCategory
->moveNext();
//dyn select
</select>
This line:
$InsertQuery->bindColumn("CatalogCategoryID", "i", "".((isset($_POST["selectedCats"]))?implode(",",$_POST["selectedCats"]):"") ."", "WA_DEFAULT");
Should be:
$InsertQuery->bindColumn("CatalogCategoryID", "i", "".($_POST["selectedCats"][$x]) ."", "WA_DEFAULT");
Thanks Ray that seems to do the trick. With regard to the Update page. I assume that's going to be more involved. because I am going to need to read in some how all the values that are stored into the catalog table so they show as selected on my update page. And then on form submit I need to perform a delete server behavior. Do u have any guidelines for this? Chris
You could just add the insert just like it is on the insert page, and then add a delete server behavior before it that deletes all of the old ones based on the CatalogProductID.... You wouldn't actually do an update, just delete them all and re-insert them all.
