Universal Email file attachment problem
Thread begun 9/04/2009 3:35 am by steen120697 | Last modified 9/08/2009 3:16 pm by Ray Borduin | 5415 views | 7 replies |
steen120697
I use UE to send attachments to different users. I retrieve email and attachment (file2send) information from a database.
If the recordset contains just 1 record, everything works fine. More than 1 record and hell breaks lose (= hundreds of emails sent).
The file2send contains the physical path.
I'd appreciate som assistance, please...
Dim Recordset1
Dim Recordset1_numRows
Set Recordset1 = Server.CreateObject("ADODB.Recordset")
Recordset1.ActiveConnection = MM_dbburner_STRING
Recordset1.Source = "SELECT * FROM LOGBOG where keycode = '" & keycode & "' and email = '" & email & "'"
response.write(Recordset1.Source)
Recordset1.CursorType = 0
Recordset1.CursorLocation = 2
Recordset1.LockType = 1
Recordset1.Open()
Recordset1_numRows = 0
<!--#include file="../WA_Universal_Email/AspMail_VB.asp" -->
<!--#include file="../WA_Universal_Email/MailFormatting_VB.asp" -->
function WA_Universal_Email_1_SendMail(RecipientEmail)
dim MailObject, MailAttachments, MailBCC, MailCC, MailTo, MailBodyFormat, MailBody, MailImportance, MailFrom, MailSubject
MailAttachments = ""
MailBCC = ""
MailCC = ""
MailTo = ""
MailBodyFormat = ""
MailBody = ""
MailImportance = ""
MailFrom = "John Doe|WA|john@company.com"
MailSubject = "Photos"
'Global Variables
gBodyFormat = ""
set WA_MailObject = WAUE_Definition("smtp.domain.com")
if (RecipientEmail <> "") then
set WA_MailObject = WAUE_AddRecipient(WA_MailObject,RecipientEmail)
else
'To Entries
end if
'Attachment Entries
while (NOT Recordset1.EOF)
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr(Recordset1.Fields.Item("file2send").Value) & "")
Recordset1.MoveNext()
wend
if (Recordset1.CursorType > 0) then
Recordset1.MoveFirst
else
Recordset1.Requery
end if
'BCC Entries
'CC Entries
'Character Set
'Body Format
set WA_MailObject = WAUE_BodyFormat(WA_MailObject,0)
MailBodyFormat = gBodyFormat
'Set Importance
set WA_MailObject = WAUE_SetImportance(WA_MailObject,"3")
'Start Mail Body
MailBody = MailBody & "Cool"
'End Mail Body
set WA_MailObject = WAUE_SendMail(WA_MailObject,MailAttachments,MailBCC,MailCC,MailTo,MailImportance,MailFrom,MailSubject,MailBody)
set WA_MailObject = nothing
end function
if ((NOT (Recordset1.EOF AND Recordset1.BOF))) then
'WA Universal Email object="AspMail"
'Send Loop Once Per Entry
WA_Universal_Email_1_SendMail("" & cStr(Recordset1.Fields.Item("email").Value) & "")
wend
else
Recordset1.Requery
end if
'Send Mail All Entries
if (""<>"") then
Response.Redirect("")
end if
end if
You need to use the full (drive relative) path to the file being uploaded.
I'm not sure exactly what you have stored in your database, but probably the answer is to use realpath() like:
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr(realpath(Recordset1.Fields.Item("file2send").Value)) & "")
steen120697
I am already using the full path: d:\www2\burner-international\img\banner\1.jpg
I copied your suggestion:
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr(realpath(Recordset1.Fields.Item("file2send"). Value)) & "")
That gives me this message:
Microsoft VBScript runtime error '800a000d'
Type mismatch: 'realpath'
The odd thing is I only have a problem when my recordset has more than one record. Everything's working fine with only one record/one attachment.
Sorry I answered too quickly... realpath is a php function... please ignore my previous response.
In ASP it is Server.MapPath(), but if you already have the full path in the database, that shouldn't be the issue.
Are you using the same recordset for the loops as the attachments? Is it possible the path is wrong in one of them?
steen120697
This is the code. I'm now using server.mappath. I have 3 files; they work individually but I cannot send 2 or more files at the same time...
Dim Recordset1
Recordset1.Open()
MailBCC = ""
MailCC = ""
MailTo = ""
MailBodyFormat = ""
MailBody = ""
MailImportance = ""
MailFrom = "John Doe|WA|john@domain.com"
'Global Variables
gBodyFormat = ""
set WA_MailObject = WAUE_Definition("smtp.domain.dk")
else
'To Entries
end if
'Attachment Entries
set WA_MailObject = WAUE_AddAttachment(WA_MailObject,"" & cStr(Server.MapPath((Recordset1.Fields.Item("file2send")). Value)) & "")
wend
else
Recordset1.Requery
end if
'BCC Entries
'CC Entries
'Character Set
'Body Format
'Set Importance
'Start Mail Body
'End Mail Body
end function
Are you using the same recordset somewhere else? When you try to send multiple it starts sending none?
I'll create a support incident so that somebody can look into this further with you.
steen120697
I am not using the same recordset anywhere else. Please note that when I want to send multiple emails I send hundreds of emails even if my recordset only contains 2 records.
I have created an incident so that someone can investigate this further with you.
