Add to cart button not working??
Thread began 8/01/2016 8:46 am by Steve_UK | Last modified 8/01/2016 1:57 pm by Ray Borduin | 1372 views | 5 replies |
Steve_UK
Hello there
Just bought and installed eCart6 - all well except the Add to Cart button does not appear to be picking up the recordset bindings.
I have to say that this is a complex page using JQuery Datatables and Bootstrap but all else is fine.
I have done the usual diagnostics to eliminate any SQL/undefined index errors etc. and the page appears clean.
Individual rows are added to the cart along with quantities from the items listing but the details don't seem to be passed through.
So for instance if I add 3 items, 3 rows are added to the cart but with blank values.
Any idea what could be amiss - anything I should look for please?
Please attach a copy of your page and I'll take a look to see if I can spot the problem.
Steve_UK
Page attached
Attached
You are filtering the rsResults recordset with a bunch of form fields, but you aren't passing those through when submitting the add to cart.
You will want to add hidden form elements for each of the fields that need values so that the rsResults recordset will still have the right rows returned when submitting the add to cart form.
Steve_UK
Ray
Thanks for that - makes sense - I'll give this a run out tomorrow.
Is it normal to have to do this with eCart?
Steve
If you do a custom recordset filter like you have based on form POST and not GET, and adding to the cart from that recordset, yes.
