From field no sending information
Thread begun 2/20/2017 8:33 am by russb335115 | Last modified 2/21/2017 1:29 pm by Ray Borduin | 4453 views | 8 replies |
russb335115
I have a form that is working great except it is not sending one of the field answer. All of the other fields are sending with no issues. I tried to debug but I don't see anything wrong with the field. Can you assist me with this issue?
Also see PM
If you open the page with the contents of the body field for that page it has code on the top that removes that field name specifically. You can either use a different field name, or just remove that code from the top of the page.
If you attach a copy of that page I can look at it and tell you the exact line of code.
russb335115
Thanks Ray, see PM
Not this page... The page that defines the body. It will be referenced in the page: webassist/email/waue_test-form_1.php
I can't even get the name of the file I need to look at from this file ;)
russb335115
Here you go
Getting closer. I can see by looking at this file that your email body comes from the page:
/webassist/email/templates/Blank_3.php
If you send me a copy of that I can explain what needs to be updated.
russb335115
Here you go :)
Line 8 has:
$removeBegins[] = "Security";
That will remove any field that begins with the word "Security".
You can simply delete that line and it will start returning the value of the missing field.
russb335115
Ok, it works. I had to remove on line 8 and 15
$removeIncludes[] = "Security";
Thanks for your help Ray :)
