adding own validation
Thread began 4/11/2017 8:10 am by software.current355386 | Last modified 4/11/2017 9:22 am by Ray Borduin | 768 views | 1 replies |
I've got contact form with i would like to select records base on postcode without letting the contact know that they have no been successful. tis is an attempt tot wart spammers which seem to get through ben though there is a security field which h must be done manually
i have added the code... goes though to thankkyou page but no emails, is it possible for you to have look at code to See where cam going wrong, tank you
You don't have any email recipients specified.
line 44 you have:
//$RecipArray[$CurIndex ][] = "";
and it should probably be:
$RecipArray[$CurIndex ][] = "" . $_POST["Email_Address"]  ."";
To silently fail and make it appear to work, update line 20 from:
PostResult($WAFV_Redirect,$WAFV_Errors,"PluginContact");
header("location: /thank-you.php");
die();
