Can eCart sync to Payeesy gatewap api?
Thread begun 5/24/2017 1:14 pm by ccdantas101117 | Last modified 7/30/2023 7:23 am by Ray Borduin | 6414 views | 14 replies |
ccdantas101117
I have a client who wants to use Bank Of America, and their system uses Payeesy.com gateway, is possible to sync ecart to Payeesy?
Documentation: https://developer.payeezy.com/select-your-integration-method
Bank of America will work with any payment gateway. That might be one they have a referral partnership with.
You can integrate any payment gateway with eCart, you would just have to follow their documentation. Since eCart is all standard PHP code, their examples and documentation should be able to be used to integrate nicely.
ccdantas101117
Thank You!
This is something I can work on in a premier support ticket.
ccdantas101117
Premier Support
I would estimate that 2 hours would be enough. Their documentation seems pretty good.
ccdantas101117
ccdantas101117
White page on success
I have the ecart working on payeesy (Ray Did the support) and it was working fine until yesterday. Now when the transaction is successfully processed, it does record it in the database, order and order detail, charge the card but instead of redirect to checkout_success page it loads the confirm.php all white page. can you help?
Try adding this to the top of the page:
<?php ini_set("display_errors",1); ?>
Then you might see an error message instead of a blank page that would give you something to work from. It could be something as simple as a space or blank line in your php before a redirect.
Dave BuchholzBeta Tester
Ray, I would be very interested in this as well if you would like to set up a premier support ticket.
