Database search which ranks results
Thread begun 4/01/2009 10:46 am by nibo | Last modified 4/01/2009 1:57 pm by Ray Borduin | 3308 views | 1 replies |
nibo
Currently using DataAssist 1, although thinking about upgrading to 2. ASP and Access DB.
As part of a shop I'm building I would like to include a simple keyword search box which looks for matches across 2-3 fields. I would like the results to be listed in order of relevance. Is this possible?
i.e. search page results are filtered on three fields - manufacturer, model and description. If the user enters "remo pinstripe", how can I make sure that the resulting recordset lists the most relevant records first?
Is it possible to weight the results toward a particular field, for example, the manufacturer?
I'm not quite sure how best to set-up the search in DataAssist. Should I just add one item which is set to compare with all of the columns I want to search or should I add a separate line for each of the columns I want to search and use the AND and OR separator?
I'm also not clear on the difference between a "value" and a "keyword".
Sorry, lots of questions. I hope someone can help. Thanks.
DataAssist won't help you order by relevance.
Keyword allows you to search across multiple columns. You should probably just use that. Then you would have to find a way to calculate the relevence and order it accordingly since DataAssist does not include that feature.
