How can I sort by column headings?
How would I set up the column headings on the results page so that I can click on them and sort the found set by that column, ascending?
Thanks!
Rich
Thanks!
Rich
You would create them as links with url parameters and then use the Sort server behavior that comes with dataassist to respond to those url parameters and create the proper sort.
I found the tutorial on how to do it. Thanks!
Can you point me to this tutorial?
Sojo Web wrote a good tutorial Making DataAssist Applications Sort-Able which would be worth looking at.
Not working
the webassist tutorial is in the Solution recipes section of the data assist support page:
dataassist/
I know that this is a *little* old, but just wondering if there is a tut or other resource on the site please Jason?
Tutorial Here:
http://www.webassist.com/tutorials/How-to-enable-sorting-of-dynamic-data
