Undefined variable in repeat selection
Thread begun 10/24/2018 2:27 am by Jonas | Last modified 11/14/2018 7:48 pm by Ray Borduin | 5306 views | 18 replies |
Jonas
I've gone through your tutorial "Create a multiple record insert form", but get an error immediately after insert repeat selection. The error message is "Notice: Undefined variable: Inga in / Applications / MAMP / htdocs / multipleRecord / webassist / sample_form_1.php on line 19
Fatal error: Uncaught Error: Call to a member function atEnd () on null in /Applications/MAMP/htdocs/multipleRecord/webassist/sample_form_1.php:19 Stacktrace: # 0 {main} thrown in / Applications / MAMP / htdocs / multiplerecord / webassist / sample_form_1.php on line 19
Note the variable name Inga which for some reason has been translated into Swedish instead of None I guess. Inga is also available in the menu.
It was a while since I was working with WebAssist. But I remember that this was a problem even then. Alternative content still does not work. I remember reading that you added this to your "to do list". But it does not seem like this server behavior has been updated in DA V2 which I'm updating now !?
Here are lines 19 to 22 by the way:
while (! $Inga-> atEnd () && $ wa_repeatfor! = 0) {
  $ Wa_repeatfor--;
  $ Wa_repeatcount ++;
  if (! $Inga-> atEnd ()) {
The code is probably keying off the word "none" and since it was translated into spanish it thinks you have selected a recordset. I'll have to debug this to figure out what went wrong and how to fix it.
For now you can manually update the code to:
$wa_repeatfor
3// Repeat Selection 1
$wa_repeatcount 0;
while (
$wa_repeatfor) {
$wa_repeatfor--;
$wa_repeatcount++;
your repeated html
// End Repeat Selection 1
Jonas
More problem
I dont think this matter but im in Sweden and I use the swedish version of Dreamweaver.
Now I have done as you said and repeat selection seems to be right now.
The next step in the tutorial is to insert multiple records. But here I get a new error: "Parse error: syntax error, unexpected" ", expecting '-' or identifier (T_STRING) or variable (T_VARIABLE) or number (T_NUM_STRING) in / Applications / MAMP / htdocs / multipleRecord / webassist /sample_form_1.php on line 16 ".
It does not seem that this server behavior works either? When I press this to update it, I get the following error message: "It's apears that one of your server-side values is incorrectly coded. Please check this interface for inconsistencies." And then it will be even worse if I continue.
I just uploaded an update to the extension that should address this issue. You will just need to reinstall the extension.
This issue is related to the foreign language version of Dreameweaver. Unfortunately I am not able to test in all language versions, so there is a distinct possibility that you will run into more issues like this. Please let me know if you do and I can attempt to fix them as they are reported. You may want to use the english DW version if possible in order to avoid this inconvenience.
Jonas
Is this still version 2.3.1?
Another thing that does not matter with this. Can you choose to get on mobile (SMS) when someone answers one's comments on the forum?
Yes, just reinstall version 2.3.1
We don't have an SMS alert option on the forums currently.
Please reply in a new post rather that updating the old one... it is hard to follow and I nearly missed that you needed a reply.
It does appear that the multiple insert is not putting the correct number of double quotes in the code. That is causing the problem live as well as when inspecting with the server behavior.
I'll take a look at that now and try to get an update. If you attach a copy of the page you are working on, I can show you what lines and code to update here in the meantime.... I may not have an update of the extension out until tomorrow since it is getting late in the day.
Jonas
I know it was a little wrong with the order in my comments.
I'm working on the multiple insert server behavior now. I found in my testing that some things weren't working properly. I'll do a full version release once I'm done. Full version releases take a lot more time, so I only tend to do them when a significant bug or feature is addressed.
Jonas
Auch, I shouldt write the last komment
