multiple insert issues
Thread begun 11/06/2018 4:03 am by georgina_barrett_187762 | Last modified 11/15/2018 5:34 am by Ray Borduin | 2114 views | 5 replies |
I am trying to create a multiple insert using the new server behaviors. I have created an recordset and added the variables to the page (within a form) I have tried using the MySQLi > Repeat Selection Improved to create a repeat region.....
$wa_repeatfor = -1; // Repeat Selection 2
if (!isset($wa_repeatcount)) $wa_repeatcount = 0;
while (!$confs->atEnd() && $wa_repeatfor != 0) {
$wa_repeatfor--;
$wa_repeatcount++;
if (!$confs->atEnd()) {
<input name="service" type="hidden" id="service" value="<?php echo($confs->getColumnVal("Service")); ?>">
<input name="Uploadconf" type="hidden" id="Uploadconf" value="<?php echo($confs->getColumnVal("UploadConf")); ?>">
if ($wa_repeatfor != 0) $confs->moveNext(); // Repeat Alternate 2
} else {
} // End Repeat Alternate 2
if (!isset($wa_startindex)) $confs->moveFirst(); // End Repeat Selection 2
And I have tried MySQLi > MySQLi Repeat Region.....
$wa_startindex = 0;
while(!$confs->atEnd()) {
$wa_startindex = $confs->Index;
$confs->moveNext();
$confs->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
However when I come to adding the Muliple Insert behaviour I get the same pop up saying 'Your page must contain form elements in a repeated region to use this interface'. I have saved each page after adding the repeat region but I just can't get it to work.
This appears to be a bug. It was reported by another user last week and I was able to reproduce it.
This is high on my priority list. I'm on vacation, but I'll be looking at this critical issue and getting an update out as soon as I can. I experienced a slight delay today when my laptop got salt water on it and died, but I bought a new laptop and will be configuring it on Thursday to pick back up on hunting down and fixing this problem
I should have a fix out in the next week or two.
OK, thank you. If you can, will you reply to this thread when you have done it - so I know to download the upgrade.
tony
I add my voice to that.
I need to do something similar and struggled a bit with this error message.
I'll wait for a solution too.
TIA
tony
I just uploaded a new version of the Multiple Insert that should fix this issue. Just reinstall the current version (I didn't update version numbers because I'm working on a few more issues I just wanted to get this out quickly for you)
Thank you, that works!
