Undefined variable
Thread begun 12/03/2018 12:57 pm by john70964 | Last modified 12/12/2018 1:22 pm by Ray Borduin | 5432 views | 15 replies |
john70964
Undefined variable
I am trying to get an image to show on the third line but am getting an error in Inspect Element of
<img src="BoatImages/<br />
<b>Notice</b>: Undefined variable: row_Recordset1 in <b>C:\xampp\htdocs\newDatabridge\test.php</b> on line <b>33</b><br />
<td width="133"><?php echo($Recordset1->getColumnVal("RecNo")); ?></td>
<td width="178"><?php echo($Recordset1->getColumnVal("Manufacturer")); ?> </td>
** <td width="200"><img src="BoatImages/<?php echo $row_Recordset1['image1_250']; ?>"></td> **
Can anyone see where I am going wrong please, Undefined variable?
John
This needs to be updated to MySQLi, so it should be:
<td width="200"><img  src="BoatImages/<?php echo($Recordset1->getColumnVal("image1_250")); ?>"></td>
john70964
Thanks Ray
The error has gone but the image shows as a square missing image.
The record details show but not the boat image.
I have checked the correct DB and table are used and have contents in the correct fields.
I also have checked the directory BoatImages/ has the correct image
which it has.
Looking at page source it shows <img src="BoatImages/"></td>
If I open Inspect Element I see the same but if I right click on the image and view image
I see
Index of /newDatabridge/BoatImages
[ICO] Name Last modified Size Description
[PARENTDIR] Parent Directory -
[DIR] _notes/ 2018-12-03 20:52 -
[IMG] cai3351.jpg 2018-12-03 20:24 18K
Apache/2.4.29 (Win32) OpenSSL/1.0.2l PHP/5.6.32 Server at localhost Port 80
If I click on the image [IMG] cai3351.jpg the correct image appears.
I hope this is clear and you can make sense of all this!
It sounds like the column name is wrong in the code. Is that the correct image column name in your database? Try writing the image name to the page somewhere to make sure you can get the value.
john70964
Re: Try writing the image name to the page
How to do this for
boatimages/Image1_250/cai3351.jpg ?
John
Add this to the page:
var_dump
($Recordset1->Results);
Then you can verify that the column name: "image1_250" is correct and that the image is saved in the database.
john70964
array(1) { [0]=> array(4) { ["RecNo"]=> int(11742) ["Manufacturer"]=> string(13) "Conyplex N.V." ["Model"]=> string(10) "Contest 29" ["Image1_250"]=> string(11) "cai3351.jpg" } }
11742 Conyplex N.V.
Ray this was the result with a little greyed out image shape.
I have checked the database fields, they all seem OK.
It looks like it should be:
<td width="200"><img  src="boatimages/Image1_250/<?php echo($Recordset1->getColumnVal("image1_250")); ?>"></td>
john70964
Hello Ray
Perhaps it may help
I have placed some files for this.
The url in in the PM it may help
The current error is saying that you haven't uploaded the file: Connections/conn1_i.php.
I'm pretty sure the the image display issue is just a bad path to the image. Maybe the wrong folder name or case sensitivity.
If you give me FTP access I can take a look at your directory structure and figure it out.
