form within repeat region submits forms
Thread begun 1/01/2019 11:35 am by davidgard | Last modified 1/02/2019 10:02 am by Ray Borduin | 855 views | 1 replies |
davidgard
I am rebuilding a web program to update to php 7. The issue I am having involves a form within a repeat region that submits to all forms when it is submitted instead of just the one form that the data was input. It worked when I built it with the native server behaviors in dreamweaver, but does not work the same using the webassist mysqli server behaviors. Any assistance would be appreciated.
Thanks,
David Gard
Probably the <form> tag should be outside of the repeat region. Only one form will submit at a time, so if you want all of the form elements to submit you need to have them inside a single form instead of multiple forms.
