iRite and CSS stylesheets
Thread began 4/01/2009 8:25 pm by tomm | Last modified 4/02/2009 12:44 pm by tomm | 3410 views | 6 replies |
tomm
Is there a way to get iRite to pick up the CSS stylesheets for a site and use them to give an accurate rendering of content within the iRite window?
On the last page of the wizard it should allow you to specify the style sheet to use. Have you tried that?
tomm
I thought that was for styling of the iRite appearance itself. I'll give it a try.
tomm
I just tried adding a stylesheet to in the last Tab of the iRite interface. It has no effect on the styling of the contents of the iRite text area.
It should... do you have a sample URL?
tomm
I take it back.
I had only updated the affected page and it didn't work. However, I just updated the javascript file associated with the page within the WA_iRite/custom directory and it took effect.
Sorry for the fire drill.
tomm
Feature Request: Link Multiple Stylesheets to iRite
It would be really good to allow linking multiple CSS stylesheets to the iRite interface, just like real web pages allow.
As it now with iRite, if you have multiple stylesheets you need to combine them into one for iRite to be able to render everything as it would appear when the content is deployed.
Multiple stylesheets for a site are pretty common.
