Same Problem with securityassist sitescribe and Surveyor..
Thread begun 9/11/2009 1:58 am by kakadong | Last modified 9/11/2009 1:58 pm by Jason Byrnes | 2312 views | 3 replies |
kakadong
After I install all extensions .....
the three extensions don't work
it looks like the same problem ...
I can't activate the three extensions .....
when I want to activate ....
it shows ......
i have spent two day to install all extensions ....
it seems like some conflict among these extensions ....
All I want is install all extensions and start my work ....
but I can't make these extensions work....
Besides .... Dataassist won't work either .....
I am so upset........
I think this error may be caused by the Chinese Operating system you are using. Unfortunately, we are not able to test our extensions on this platform so it is not officially supported.
I am going to open a support ticket for this so one of our engineers can look into the problem in more detail to see if there is anything we can do to resolve the issue. To view and edit you support ticket, log into your support history:
kakadong
I am trying to get a DW4(english) ...
and I hope it will solve all problem I met ....
but before that ....
if the DW4-TC edtion is the problem ...
why the others work fine
for example : CSSmenu Writer CSS form builder
to be 100% honest, I'm not sure. this is why I have created a support ticket: so our engineers can look into the issue with you to determine the cause of the problem, and see if there is a fix for it.
