ClamAV reported a infected file on base.js
Thread begun 2/03/2019 3:01 am by Mike | Last modified 2/04/2019 1:41 pm by Ray Borduin | 1852 views | 2 replies |
Mike
Today I've received an alert from my ClamAV antivirus activated on my server:
[VIRUS!] - ClamAV scan report
Infected files: 1
This is the file that ClamAV reported as "infected":
/var/www/vhosts/domain.com/httpdocs/webassist/kcfinder/cache/base.js: Txt.Trojan.Coinminer-6840768-0 FOUND
If you want to check, scan the attachment file on this website (at the end of the scanning process, see "ClamAV" in the report):
https://www.virustotal.com
Is it a false positive alarm that can I ignore?
Thanks.
It appears to be a false positive. If I just combine the jquery with the jquery UI javascript files into one document it shows the error, but scanning each individually doesn't.
However, it does appear that updating from jquery 1.11 to jquery 1.12 fixes the error, so I'll get it updated. Here are the files you can update to fix the issue in the meantime.
Just replace:
/webassist/kcfinder/js/000._jquery.js
/webassist/kcfinder/js/002._jqueryui.js
000._jquery.js
002._jqueryui.js
Mike
Hi Ray... I've updated the two files and now ClamAV reported me "0" files infected after scanning.
Thanks!
