Editor showing code
Thread begun 2/14/2019 8:54 am by Patrice | Last modified 2/14/2019 1:49 pm by Ray Borduin | 7363 views | 28 replies |
PatriceWebAssist
Editor showing code
I have read a number of solutions but am still lost. I have the latest DA; I removed the older ck folder (this is a redo on an older site). Redid an html editor, re-upped the new version of CK folder.
The only thing different on this work, is that I am using the new mysqli approach. So the insert and the update html editors are showing <p> and <br> and <h1> etc.
You have to turn off Cross Site Scripting protection in the set value by adding the "false" argument to the end of the ->getColumnVal() method call where it is referenced in the HTML editor code. It will look like:
$RSname->getColumnVal("columnName",false)
If you have trouble finding the line to update, attach your update page and I can help with line numbers and a more specific code reference.
PatriceWebAssist
Thanks Ray. I had just finished another site yesterday and it worked fine. So I deleted the web assist folder and replaced it with the one from the other site. I'm uploading it via transmit now. If that doesn't work, then I will try to find the change for the updater page. Thanks.
PatriceWebAssist
Laugh. That wiped out all my pages. Total blank. So much fun. I'll see what I can do before bothering you.
PatriceWebAssist
OK... retrieved from last night's back up. I have the Update page open and am looking at the code for the editor.
// The initial value to be displayed in the editor.
$CKEditor_initialValue = "".((isset($_GET["invalid"])?ValidatedField("2019pagecopyupdate","pc_content",false):"".$WADA2019pagecopy_update->getColumnVal("pc_content",false)."")) ."";
$CKEditor = new CKEditor();
$CKEditor->basePath = "../webassist/ckeditor/";
$CKEditor_config = array();
$CKEditor_config["wa_preset_name"] = "2018";
$CKEditor_config["wa_preset_file"] = "2018.xml";
$CKEditor_config["width"] = "700px";
$CKEditor_config["height"] = "350px";
$CKEditor_config["docType"] = "<" ."!" ."DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\" \"http://www.w3.org/TR/html4/loose.dtd\">";
$CKEditor_config["contentsLanguage"] = "";
$CKEditor_config["dialog_startupFocusTab"] = false;
$CKEditor_config["fullPage"] = false;
$CKEditor_config["tabSpaces"] = 4;
$CKEditor_config["toolbar"] = array(
array( 'Source','-','Save','NewPage','Preview','-','Templates'),
array( 'Cut','Copy','Paste','PasteText','PasteFromWord','-','Print','SpellChecker','Scayt'),
array( 'Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'),
array( 'Bold','Italic','Underline','Strike','-','Subscript','Superscript'),
array( 'NumberedList','BulletedList','-','Outdent','Indent','Blockquote','CreateDiv'),
array( 'Link','Unlink','Anchor'),
array( 'Table','HorizontalRule','SpecialChar','PageBreak'),
array( 'Styles','Format'),
array( 'TextColor'),
array( 'Maximize','ShowBlocks','-','About'));
$CKEditor_config["contentsLangDirection"] = "ltr";
$CKEditor_config["entities"] = false;
$CKEditor_config["forcePasteAsPlainText"] = true;
$CKEditor->editor("pc_content", $CKEditor_initialValue, $CKEditor_config);
PatriceWebAssist
Ah... this won't be the latest since I pulled last nights back up... have to redo again. I will need to dump the ck folder and reinstall.
PatriceWebAssist
ok... now I am looking at this
$CKEditor_config["width"] = "514px";
PatriceWebAssist
A search on the updater page of
didn't have any result.
It looks like you have it correct on the page:
I'm wondering what version of webassist/mysqli/rsobj.php you have on your site. Maybe it needs to be updated? If you can give me FTP access and a URL with username/password so I can view the error then I'm sure I can find the right solution.
PatriceWebAssist
I just downloaded DA again and installed. I'll check on the other one before trying again.
