Calculate average from form fields
Thread begun 3/22/2019 5:31 pm by Jonas | Last modified 3/25/2019 9:03 am by Ray Borduin | 996 views | 2 replies |
Jonas
I have a form that consists of rating in 8 different categories. Everything is in the same table, so no relationship. The fields are 'Kat1Rating', 'Kat2Rating' up to 8. Now I want to auto-generate an average rating from these categories, which should be displayed on the detail- and results-page.
On the Internet I found a solution that was to create a new query on the detail-page. This turned out to work perfectly, on the detail page. But since it's in a separate query, it doesn't work on the results-page. Even if I re-create the same query there, I get the same average on all records.
Unfortunately, it is a rather advanced query, and I do not know how to incorporate it in the original query created by DA. Unfortunately, Query builder does not seem to be able to help me here.
Here is the queries...
Average query on detail-page (this is working on the detail-page):
$rsAverage = new WA_MySQLi_RS("rsAverage",$matematikSverige,1000);
$rsAverage->setQuery("SELECT (CAST(AVG(`kat1Betyg`+`kat2Betyg`+`kat3Betyg`+`kat4Betyg`+`kat5Betyg`+`kat6Betyg`+`kat7Betyg`+`kat8Betyg`) /8 AS DECIMAL(10,1))) AS average FROM laromedel");
$rsAverage->execute();
Query on results-page generated by DA:
$WADAlaromedel = new WA_MySQLi_RS("WADAlaromedel",$matematikSverige,1000);
$WADAlaromedel->setQuery("SELECT id, bild, laromedelsnamn, arskurser FROM laromedel");
$WADAlaromedel->execute();
Query on detail-page generated by DA:
$WADAlaromedel_details = new WA_MySQLi_RS("WADAlaromedel_details",$matematikSverige,1);
$WADAlaromedel_details->setQuery("SELECT laromedel.id, laromedel.laromedelsnamn, laromedel.bild, laromedel.arskurser, laromedel.utvecklare, laromedel.pris, laromedel.adaptivt, laromedel.heltackande, laromedel.testad, laromedel.kat1Betyg, laromedel.kat1Kommentar, laromedel.kat2Betyg, laromedel.kat2Kommentar, laromedel.kat3Betyg, laromedel.kat3Kommentar, laromedel.kat4Betyg, laromedel.kat4Kommentar, laromedel.kat5Betyg, laromedel.kat5Kommentar, laromedel.kat6Betyg, laromedel.kat6Kommentar, laromedel.kat7Betyg, laromedel.kat7Kommentar, laromedel.kat8Betyg, laromedel.kat8Kommentar, former.`text` AS former_text, avsettfor.`text` AS avsettfor_text FROM laromedel LEFT OUTER JOIN former ON laromedel.form_id = former.id LEFT OUTER JOIN avsettfor ON laromedel.avsettfor_id = avsettfor.id WHERE laromedel.id = ?");
$WADAlaromedel_details->bindParam("i", "".($_GET['id']) ."", "-1"); //WAQB_Param1
$WADAlaromedel_details->execute();
Maybe I'm overworking. Is there any easier way? Grateful for help.
You can just add it to the results page query:
$WADAlaromedel_details->setQuery("SELECT (CAST(AVG(`kat1Betyg`+`kat2Betyg`+`kat3Betyg`+`kat4Betyg`+`kat5Betyg`+`kat6Betyg`+`kat7Betyg`+`kat8Betyg`) /8 AS DECIMAL(10,1))) AS average, laromedel.id, laromedel.laromedelsnamn, laromedel.bild, laromedel.arskurser, laromedel.utvecklare, laromedel.pris, laromedel.adaptivt, laromedel.heltackande, laromedel.testad, laromedel.kat1Betyg, laromedel.kat1Kommentar, laromedel.kat2Betyg, laromedel.kat2Kommentar, laromedel.kat3Betyg, laromedel.kat3Kommentar, laromedel.kat4Betyg, laromedel.kat4Kommentar, laromedel.kat5Betyg, laromedel.kat5Kommentar, laromedel.kat6Betyg, laromedel.kat6Kommentar, laromedel.kat7Betyg, laromedel.kat7Kommentar, laromedel.kat8Betyg, laromedel.kat8Kommentar, former.`text` AS former_text, avsettfor.`text` AS avsettfor_text FROM laromedel LEFT OUTER JOIN former ON laromedel.form_id = former.id LEFT OUTER JOIN avsettfor ON laromedel.avsettfor_id = avsettfor.id WHERE laromedel.id = ?");
Jonas
Thank you Ray for your reply, but unfortunately your proposal does not work. I get an SQL error.
But now it seems that I found the solution on the results page where the problem was:
SELECT (CAST(AVG(`kat1Betyg`+`kat2Betyg`+`kat3Betyg`+`kat4Betyg`+`kat5Betyg`+`kat6Betyg`+`kat7Betyg`+`kat8Betyg`) /8 AS DECIMAL(10,1))) AS average, `id`,`bild`,`laromedelsnamn`,`arskurser` FROM laromedel GROUP BY `id`
...and on the details page, I managed to group the two querys to one:
SELECT(CAST(AVG(laromedel.kat1Betyg + laromedel.kat2Betyg + laromedel.kat3Betyg + laromedel.kat4Betyg + laromedel.kat5Betyg + laromedel.kat6Betyg + laromedel.kat7Betyg + laromedel.kat8Betyg) /8 AS DECIMAL(10,1))) AS average, laromedel.id, laromedel.laromedelsnamn, laromedel.bild, laromedel.arskurser, laromedel.utvecklare, laromedel.pris, laromedel.adaptivt, laromedel.heltackande, laromedel.testad, laromedel.kat1Betyg, laromedel.kat1Kommentar, laromedel.kat2Betyg, laromedel.kat2Kommentar, laromedel.kat3Betyg, laromedel.kat3Kommentar, laromedel.kat4Betyg, laromedel.kat4Kommentar, laromedel.kat5Betyg, laromedel.kat5Kommentar, laromedel.kat6Betyg, laromedel.kat6Kommentar, laromedel.kat7Betyg, laromedel.kat7Kommentar, laromedel.kat8Betyg, laromedel.kat8Kommentar, former.`text` AS former_text, avsettfor.`text` AS avsettfor_text FROM laromedel LEFT OUTER JOIN former ON laromedel.form_id = former.id LEFT OUTER JOIN avsettfor ON laromedel.avsettfor_id = avsettfor.id WHERE laromedel.id = ?
