wa querybuilder script define find server behaviors function
Thread begun 4/28/2019 8:13 pm by MAURIANS | Last modified 5/02/2019 11:05 am by Ray Borduin | 5000 views | 11 replies |
MAURIANS
loading pages in dreamweaver cs6 I get wa querybuilder script does not define the find server behaviors function
Try clearing your winfilecache.dat file in your user's configuration folder. This sounds like a cached error that may be cleared up by deleting that file.
MAURIANS
I cleared the cache and still getting same error, I backed up old files and restored and issue remains...
What extensions do you have installed? I don't think we have a server behavior named "wa querybuilder" anymore... I believe that is a very old version of the WA QueryBuilder extension, which has been replaced by DataBridge, which I see you own.
I think you may need to uninstall some of the older extensions you have installed and then you should only install: Free Tools, Data Bridge, eCart, and MySQLi Server Behaviors. The other extensions you have are either outdated or included in Data Bridge.
MAURIANS
ecart 6
data bridge
WA QueryBuilder 2.5
WA Querybuilder is old and has been incorporated into DataBridge. You probably just need to uninstall it and re-install DataBridge.
MAURIANS
What is difference(s) of DATABRIDGE V2
DataBridge v2 includes improved email functionality, MySQLi Support for all of the wizards, and migration tools to migrate MySQL code to MySQLi.
MAURIANS
So far so good, thanks
MAURIANS
After uninstalling old plugins and reinstalling Data Bridge V1 including deletion of cache file, the Dynamic Web Charts wizard is not functioning nor showing up in Dreamweaver CS6 insert tab or other locations.
