redirect after insert
Thread began 5/03/2019 8:38 am by Sweens | Last modified 5/05/2019 1:50 pm by Ray Borduin | 500 views | 4 replies |
Sweens
Hi Ray
I'm trying to redirect to dynamic page after insert, but I keep getting 'error in your SQL syntax after submitting the form. The form itself works, and inserts the record.
I'm trying to use:
$InsertGoTo = "".$rsPageContent->getColumnVal("site_url")."/thanks.php";
If I just use
$InsertGoTo = "thanks.php";
it's fine.
Cheers
Chris
The code looks fine. Is the $rsPageContent on the page and above the insert code?
Adding a redirect should never cause a SQL syntax error.. so something else is causing that.
Sweens
Thanks Ray
Yes, the recordset is above the insert. As I say, it works fine until the dynamic bit is added. I've attached the page.
Chris
I can't see the problem. Can you post the page live with the error and give me FTP access? I'll need precise steps on how to see the error, then I'll use that to reproduce the problem and debug it from there.
Sweens
Many thanks Ray
Mea Culpa, I'm afraid; I've simplified the 'thanks' page and it no works without error.
Sorry to waste your time.
Cheers
Chris
