Warning expects parameter on rsobj.php
Thread begun 5/06/2019 3:53 pm by eric284736 | Last modified 5/07/2019 9:46 am by Ray Borduin | 2897 views | 6 replies |
eric284736
Hi Ray,
I am getting some warning errors on a site. I duplicated the original site that has no errors.
This is what I am getting:
Warning: mysqli_stmt_result_metadata() expects parameter 1 to be mysqli_stmt, boolean given in /home/ocsalum4/public_html/webassist/mysqli/rsobj.php on line 478
Warning: mysqli_num_fields() expects parameter 1 to be mysqli_result, null given in /home/ocsalum4/public_html/webassist/mysqli/rsobj.php on line 480
Warning: mysqli_fetch_fields() expects parameter 1 to be mysqli_result, null given in /home/ocsalum4/public_html/webassist/mysqli/rsobj.php on line 481
Warning: mysqli_free_result() expects parameter 1 to be mysqli_result, null given in /home/ocsalum4/public_html/webassist/mysqli/rsobj.php on line 483
Warning: mysqli_stmt_store_result() expects parameter 1 to be mysqli_stmt, boolean given in /home/ocsalum4/public_html/webassist/mysqli/rsobj.php(472) : eval()'d code on line 1
Warning: mysqli_stmt_bind_result() expects parameter 1 to be mysqli_stmt, boolean given in /home/ocsalum4/public_html/webassist/mysqli/rsobj.php(472) : eval()'d code on line 1
Is this a SQL error?
thx
Eric
My guess is that the connection information is wrong for the new site. If you give me FTP access I could verify.
eric284736
Thanks Ray. See PM
I turned on Debug in your rsobj.php file and now it shows an error. The issue is that your database doesn't have the tables you are using in it.
eric284736
Thanks Ray!
How do I turn on the debug mode?
thx
Eric
You open the rsobj.php file and set the value where it says "Debug" from false to true.
eric284736
Thanks Ray!
