Is possible to use CKFinder with the html editor?
Thread begun 5/17/2019 2:02 am by Mike | Last modified 12/07/2019 2:12 am by anonymous | 2440 views | 5 replies |
Mike
Hello,
is possible to activate "CKFinder" in the CKEditor4 included with DataBridge?
https://ckeditor.com/ckfinder/
If yes, do you have a tutorial/guide to do it without to create issues with DataBridge?
Thanks.
It is possible, but we don't have a tutorial or guide for it. You should be able to follow the CKFinder documentation. Our CKEditor integration is the same as the one distributed from the CKEditor site. It should just be a matter of setting up the CKFinder files and then changing the file manager link in the code to point to your CKFinder directory instead of the KCFinder that it uses natively.
Mike
Ok, thanks Ray. I'll try to see with more attention the documentation (at first glance the configuration procedure seemed complicated to me).
Do you know if I need to buy any license to use it?
Yes, CKFinder is a for sale product. That is why we integrated KCFinder instead.
Mike
Ok, thanks.
anonymous
Reply
This post has been deleted.
