Affiliate data logs with DataAssist
Thread begun 9/16/2009 7:05 am by georgina_barrett_187762 | Last modified 9/24/2009 5:48 pm by Jimmy Wu | 5072 views | 8 replies |
I am creating an ecommerce site with an affiliate login. I have created the site and the affiliate log in. I can track orders placed by people coming from an affilate site by storing the url variable affilateID in a session and then storing it in the orders table. What I want to know though - is there a way of tracking how many people came to the site from an affiliate site - even if they didn't buy anything?
Jimmy Wu
At the top of each page, you can have code that inserts into the table or increments a value in the table every time a page is accessed with that particular associate ID. This would keep track of the number of page views that a user accesses your pages through that particular associate ID.
Thank you - but being relatively new to php please could you give me an idea of the code I would need to do this or point me in the right direction to find out.
I have tried this
(database table is called Hits with 2 columns AffiliateID and Counter)
<?php require_once('Connections/mainconnect.php'); ?>
if (!@session_id()) {
session_start();
$AffiliateID = $_GET["AffiliateID"];
mysql_select_db($database_mainconnect, $mainconnect);
mysql_query("UPDATE Hits SET Counter = Counter+1 WHERE AffiliateID=$AffiliateID;");
header('Location: ' . $AffiliateID);
} else {
header('Location: '.$AffiliateID);
mssql_close($con);
However when I load the page it automatically returns me to my homepage - I don't have any page access restricts on it.
Jimmy Wu
You can set up the DataAssist server behavior: Single Record Insert to insert the value into the database if you like instead of hand coding the insert.
Set the trigger to before page load and leave the Go to as blank. Set the value to be inserted as the parameter value.
Thank you. I have created an insert record on page load and set the affiliate id field to <?php echo $_GET['site']; ?> so that everytime that page is loaded with ?site=.... in the url it will add a record.
It would be a lot better if I could use an increment value (to save database space) so each time someone arrives from a certain site it updates the number rather than adding a row. How would I do this can I do it from update record or would I need to hand code?
Jimmy Wu
You can use the update server behavior to achieve the increment, you should not have to hand code the update.
Thank you. I have tried using the Update > Update Single Record behaviour. But what code would I need to put in the value field. I can insert 1 into the value but I don't know how to keep adding 1 everytime.
Jimmy Wu
The value would be the name of the affiliate or affiliate ID as it is stored in the table. The key column would be the affiliate name or affiliate ID column depending on what you're passing into the URL parameter.
Before you can use the URL parameter in the server behavior, you will have to add it to the page bindings. You can do this by going to the Bindings panel and hitting the "+" button and selecting URL Variable. In the popup, enter the name of the url variable you are using and hit ok.
You will also have to get the current count for that affiliate. You can do this by adding a recordset and looping through until you get the correct value. Then store this in a variable and use this to update the value of the field.
