Show doesn't work with paging
Thread begun 7/26/2019 5:15 pm by Nigel | Last modified 8/07/2019 3:44 pm by Ray Borduin | 3940 views | 17 replies |
Nigel
If I try to set "< Previous | Next >" paging navigation links to hide either word depending if there are other pages or not I'm being told there's an error in my code. I'm using a mysql record set and record set paging and show region from the Webassist menu. I also get the same error if I try to display record count.
It may be that you are using an older version of the rsobj.php file that has errors that have already been addressed in the current version. I've attached the latest version of that file. If replacing it doesn't help, then I'd probably need a URL to reproduce the issue and FTP access to debug it in order to get to the bottom of this issue.
Nigel
No joy. I've just reinstalled everything anyway after CC upgrade, so should be up to date. I've fudged it for now with:
<?php if($_GET['pageNum_shop']!=0){?><a href="<?php echo $shop->getPrevPageLink(); ?>">< Previous</a><?php }else{?><?php };?>
...but it's not ideal.
It looks like your server may have IP restrictions on the FTP access... I can't connect. Please verify that the ftp information provided is correct and that there are no IP restrictions that may be blocking my access and I can try again.
Nigel
Sorry forgot I have to unlock it - I've done that now.
My IP Address Is:
IPv6: 2601:402:401:6706:7109:8646:7e28:4bc6
IPv4: 68.36.234.43
I just tried and still couldn't get in. Let me know when you have white listed my IP and I'll try again.
Nigel
IPv4 applied (won't accept v6) for Remote MySQL Access and FTP.
I'm still getting a connection refused message when I try to get to that server. It appears the IP restrictions are still in place since I can't even reach the server to test the username and password. Are you sure the server url is correct? I'm using copy/paste from your previous thread.
Nigel
New details below.
I'm back to my office, which has a different IP address. Please white list: 76.176.134.27
I can't currently connect through FTP, but that might be the issue.
