files not deleted but record updated
Thread begun 8/30/2019 8:41 am by Sweens | Last modified 9/03/2019 10:00 am by Ray Borduin | 1423 views | 3 replies |
Sweens
Hi Ray
I've scoured the support forums, but the solutions don't apply here.
I'm trying to delete a big picture and 2 thumbnails, then update the record with blank value, so that a replacement can be uploaded on a different page.
However, the image deletion isn't working. If I have the update record behaviour set to update record when the page loads, the record is updated, but the images aren't deleted.
I've changed the page so that the record is updated if delete3 is successful, but now the page just hangs.
Can you spot anything obvious?
Many thanks, as ever
Chris
Sweens
Ray?
I don't see the issue in the code. I'd need FTP access and a URL to debug. Are you sure the column names and folder paths are correct?
Sweens
Thanks Ray - I don't know how I missed it, but there were 2 instances of PagemainPics instead of PageMainPics. Once I'd corrected this, the deletions worked fine.
Sorry to trouble you
Cheers
Chris
