Manually changing to encryption
Thread begun 10/17/2019 2:48 pm by EmmaMorris | Last modified 11/07/2019 11:20 am by Ray Borduin | 2456 views | 9 replies |
EmmaMorris
I am trying to convert one of my database login pages to encryption instead of plain text.
I have no pc with Windows on it at this point in time so I am trying to do it manually.
I created a separate add user page that is using 'password_hash' and verified that part works properly.
My question is this... Here is the line of webassist code
$Authenticate->addFilter("passwd", "=", "s", "".((isset($_POST["Password"]))?$_POST["Password"]:"") ."");
and here is what I changed it to..
$Authenticate->addFilter("passwd", "=", "s", "".((isset($_POST["Password"]))?password_hash($_POST["Password"], PASSWORD_DEFAULT):"") ."");
I am not getting any errors now but it will not log in... Is there a glaring error anywhere.. What am I missing?
Hoping to get a Windows pc set back up soon but in the mean time I would like this part fixed if possible
Thanks.
Emma.
The UI doesn't fully support hashed passwords, so you have to change the code manually... Update this:
$Authenticate->addHash("passwd", "".(isset($_POST["Password"])?$_POST["Password"]:"") ."");
EmmaMorris
Coming up with this error now.
What version of the authentication.php file do you have? I added the addHash() capability later, maybe you have to install the latest version of DataBridge to get the latest version of that file. I'll send you my version.
EmmaMorris
I had v1.16. I swapped it out. I get no error but it will not login with a logon/pw that I know are encrypted with the password_hash.
Unless you have another easy idea, I dont want to waste any more of your time. I will have to get a pc up and running with Windows and get Databridge reinstalled. I may have a vm with it on it so I will find out.
Thanks for your help!
Emma
I actually had a mistake in the line of code I gave you. I've corrected it in the post above if you want to try again.
EmmaMorris
That did it.. Thank you so much...
I still need to do the add and edit user pages but that can wait until I get it the software reinstalled... I have another page to add them with encryption
Have a great rest of the week!
Emma
EmmaMorris
Encryption on insert/update pages
So I have the login page working fine with encrypted passwords. Have not been able to get it going on the insert and update pages.
My question is this, Can I just tweak those similar lines on the insert and update pages or will more be involved.?
This is the code you gave me for the login page.
Below are the passwd lines from the update and insert page
$UpdateQuery->bindColumn("passwd", "s", "".((isset($_POST["Password"]))?$_POST["Password"]:"") ."", "WA_IGNORE");
$InsertQuery->bindColumn("passwd", "s", "".((isset($_POST["Password"]))?$_POST["Password"]:"") ."", "WA_DEFAULT");
Thanks so much for your help.
Emma
Use:
$UpdateQuery->bindColumn("passwd", "s", "".((isset($_POST["Password"]))?password_hash($_POST["Password"], PASSWORD_DEFAULT):"") ."", "WA_IGNORE");
$InsertQuery->bindColumn("passwd", "s", "".((isset($_POST["Password"]))?password_hash($_POST["Password"], PASSWORD_DEFAULT):"") ."", "WA_DEFAULT");
EmmaMorris
Thanks for the quick reply!
I was close.. I tried it but it was in the wrong spot...
Works perfect.
Thanks again! Saved me a BUNCH of time.
Emma
