nested
Thread begun 10/20/2019 3:37 pm by rayne202093 | Last modified 10/21/2019 12:40 pm by Ray Borduin | 1648 views | 4 replies |
rayne202093
nested
I have a nested repeat region that was converted using databridge. The code produced is:
$master1events = new WA_MySQLi_RS("master1events",$clarion_i,0);
$master1events->setQuery("SELECT * FROM (events LEFT OUTER JOIN eventsDate ON events.events_ID=eventsDate.event_IDfk) GROUP BY event ORDER BY eventsDate.eventDate ASC LIMIT 0, 20");
$master1events->execute();
$detail2eventsDate = new WA_MySQLi_RS("detail2eventsDate",$clarion_i,1);
$detail2eventsDate->setQuery("SELECT * FROM eventsDate WHERE event_IDfk=123456789 ORDER BY eventsDate.eventDate ASC ");
$detail2eventsDate->execute();
<table border="0" cellpadding="0" cellspacing="0">
$wa_startindex = 0;
while(!$master1events->atEnd()) {
$wa_startindex = $master1events->Index;
<tr>
<td><p class="event-title"><?php echo $master1events->getColumnVal('eventimg'); ?> <?php echo $master1events->getColumnVal('event'); ?></p>
<p class="event-desc"><?php echo $master1events->getColumnVal('desc_front'); ?></p></td>
</tr>
if ($master1events->TotalRows>0) {
$nested_query_detail2eventsDate = str_replace("123456789", $master1events->getColumnVal('events_ID'), $query_detail2eventsDate);
mysql_select_db($database_clarion);
$detail2eventsDate = mysql_query($nested_query_detail2eventsDate, $clarion) or die(mysql_error());
$row_detail2eventsDate = mysql_fetch_assoc($detail2eventsDate);
$detail2eventsDate->TotalRows = mysql_num_rows($detail2eventsDate);
$nested_sw = false;
if (isset($row_detail2eventsDate) && is_array($row_detail2eventsDate)) {
do { //Nested repeat
<tr>
<td><p class="event-para"><strong><?php echo $detail2eventsDate->getColumnVal('location'); ?></strong>: <?php echo $detail2eventsDate->getColumnVal('dateDisplay'); ?>
// Show IF Conditional region1
if (@$detail2eventsDate->getColumnVal('link') != null) {
<a href="<?php echo $detail2eventsDate->getColumnVal('link'); ?>">Read more</a>
if (@$detail2eventsDate->getColumnVal('regLink') != null) {
| <a href="<?php echo $detail2eventsDate->getColumnVal('regLink'); ?>">Register</a>
<?php }
// endif Conditional region1
// Show IF Conditional region5
if (@$detail2eventsDate->getColumnVal('online') == 1) {
&nbsp;<em>(Online or In-person)</em>
<?php }
// endif Conditional region5
</p>
<?php }
?></td>
</tr>
} while ($row_detail2eventsDate = mysql_fetch_assoc($detail2eventsDate)); //Nested move next
<tr>
<td>&nbsp;</td>
</tr>
$master1events->moveNext();
$master1events->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
</table>
The code does not work. Do I have to change the way the second recordset is setup? Maybe change event_IDfk=123456789?
Thanks for any help.
This section is still in mySQL... Because it was hand-coded, it can't be updated by the extension:
$nested_query_detail2eventsDate str_replace("123456789"$master1events->getColumnVal('events_ID'), $query_detail2eventsDate);
$detail2eventsDate mysql_query($nested_query_detail2eventsDate$clarion) or die(mysql_error());
$row_detail2eventsDate mysql_fetch_assoc($detail2eventsDate);
$detail2eventsDate->TotalRows mysql_num_rows($detail2eventsDate);
$nested_sw false;
if (isset(
do {
//Nested repeat
<tr>
<?php }
<?php }
</p>
<?php }
?></td>
</tr>
} while ($row_detail2eventsDate mysql_fetch_assoc($detail2eventsDate)); //Nested move next
I think it should be something like:
$detail2eventsDate
$detail2eventsDate->setQuery($nested_query_detail2eventsDate);
$nested_sw
false;
while (!$detail2eventsDate->atEnd()) {
<tr>
if ($detail2eventsDate->getColumnVal('link')) {
if ($detail2eventsDate->getColumnVal('regLink')) {
<?php }
if ($detail2eventsDate->getColumnVal('online') == 1) {
<?php }
</p>
<?php }
?></td>
</tr>
  $detail2eventsDate
->moveNext();
rayne202093
Thank you for the help. I get an error "Notice: Undefined variable: query_detail2eventsDate" on this line:
How should I change that line?
Thanks.
Maybe just delete that line and use:
$detail2eventsDate
$detail2eventsDate->setQuery("SELECT * FROM eventsDate WHERE event_IDfk= "$master1events->getColumnVal('events_ID') ." ORDER BY eventsDate.eventDate ASC");
rayne202093
That worked perfectly. Thank you so much.
