Email logging error
Thread begun 8/26/2020 9:07 am by Mags | Last modified 8/26/2020 12:37 pm by Ray Borduin | 2308 views | 8 replies |
Mags
Email logging error
I've just added email logging to a registration form. The database table was autocreated, email is sending but I got a blank page after submission. Turned on error logging and got the attached errors - can't figure out what the problem is though. Can you help?
Please attach a copy of the page:
session-register.php
Most errors seem to come from there. I may be able to spot what is wrong.
Mags
Here it is.
This code is wrong on the top of the page:
foreach($_POST as $event => $val) {
if(is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
The variable names don't match up. I think it should be:
foreach($_POST as $key=> $val) {
Line 53 you have:
$Email->onSend = new Email_Log("insert","email_log","EmailTo",$PowerCMSConnection_i);
$Email->onSend = new Email_Log("insert","email_log","EmailTo",$Exclusives_i);
Delete your error log after making those changes and run it again. If you have more issues let me know and I can investigate further. Make sure to attach the updated version of the file in your response.
Mags
Updated error messages and page attached - still not logging in the database.
It looks like the log table wasn't created properly. I see the error:
paradigm_mort.email_log
You may have to create that table on the live database if it was created locally.
Also i see an error in the file: webassist/email/event-booking.php on line 8
I'd need a copy of that file to tell you what is wrong with it.
Mags
I just let Universal Email create the log table for me - it was created on the live database. I've attached a copy of the event-booking.php email. Have also included SFTP details in the PM.
Line 8 is:
<p>Event: <?php echo ((isset($_POST["event"]))?implode(", ", $_POST["event"]):"")?></p>
It needs to be:
<p>Event: <?php echo ((isset($_POST["event"]))?(is_array($_POST["event"])?implode(", ", $_POST["event"]):$_POST["event"]):"")?></p>
The FTP information provided doesn't seem to work for me. However I see in the log:
Table 'paradigm_mort.email_log' doesn't exist
Maybe the database name is wrong? The error seems to clearly state the table is missing from that database.
Mags
I just realised that I don't need the actual email log details so I just added a separate Insert Record behavior to the page and that gives me what I need. I will likely have an email log I'll need to build for another client though, so I may well be back in touch...!
