Support for UniversalEmail
Thread begun 9/18/2009 1:25 pm by mikal83632 | Last modified 9/24/2009 1:15 pm by Ray Borduin | 10130 views | 11 replies |
mikal83632
Do you only get one support ticket when you purchase? I need some help really what are my options?
I just need to figure out why an email is not sending emails. I have one that works and the other nothing.
Can someone contact me to help?? I have watched the videos and I have one working but not the other. Maybe you can see something I am doing wrong simply but I need some help with the software.
Thank you
anonymous
There are plenty of people that will help... could you give us some more details about the form not working... such as your platform (is it PHP? CF? ASP?) and then maybe post the code of the one that is not working?
First and foremost, make sure you explicitly upload all the files... remember that with each instance of Universal Email, it creates a new mailer files in the Universal Email Folder... so make sure all of it is uploaded to the server.
Also, with support tickets, there is no limitation, per se... WebAssist is now making the forum the entry point to report problems and issues and if need be, they will create a support ticket if the problem appears specific to one person. But with the forum method, it allows everyone who may be experiencing the same problem to see what has already been reported, what is being done about it, and furthermore, allows them to see the fixes for said problem.
Best regards,
Brian
Jimmy Wu
Thanks Brian, that's correct, the Support forum is now the first line of support now. If you post here and there are additional files/private information that is needed to solve the issue, a backend support ticket will be created for you as our support engineers see fit.
We will need some more information or details on how you set up the two. Are you running them on the same server or on different servers? Make sure that they both have mailing capabilities set up if you are running on different servers. If you're not, could you specify what details you put in for the two different email behaviors when setting them up?
I know in some versions of php on windows the email won't send if you include a from or to name. Try leaving the name portion blank and only use the email address in those areas and it may fix the problem.
mikal83632
What do i need to show
Trying this again.
But I have one form working ok.
I set up another one to work in the same directory.
1. pulled up the form page.
2. Set form tag names
3. Opened UVM set up prams
4. Got to DW edit part
5. Copy and pasted form and saved.
6. Uploaded everything.
7. It just does nothing online.
Im going to try this again now and see if it works - dont have much confidence not sure what I am doing wrong here.
mikal83632
What I have that does not work code
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "bespy@pufferfishnow.com";include("WA_Universal_Email/WAUE_landing-ad_1.php");
$RecipientEmail = "tkelly@pufferfishnow.com";include("WA_Universal_Email/WAUE_landing-ad_1.php");
//Send Mail All Entries
if ("thankyou.html"!="") {
header("Location: thankyou.html");
$RecipientEmail = "bespy@pufferfishnow.com";include("WA_Universal_Email/WAUE_landing-ad_2.php");
$RecipientEmail = "tkelly@pufferfishnow.com";include("WA_Universal_Email/WAUE_landing-ad_2.php");
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8"/>
<meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />
<title>PufferFish Home</title>
<link type="text/css" rel="stylesheet" href="css/all.css"/>
<!--[if lt IE 7]><link type="text/css" rel="stylesheet" href="css/ie6.css"/><![endif]-->
</head>
<body class="home">
<div id="main-container">
<div class="mc-holder1">
<div class="mc-holder2">
<!--main start-->
<div id="main">
<!--header start-->
<div id="header">
<!--logo-->
<strong class="logo"><a href="#">HuddleUp</a></strong>
<span class="text-donthave">YOU DON'T HAVE LOOK BIG TO BE BIG</span>
<!--nav-holder-->
<div class="nav-holder">
<ul class="navigation">
<li><a class="home" href="index.html">home</a></li>
<li><a class="company" href="company.html">company</a></li>
<li><a class="what" href="big-picture.html">what we do</a></li>
<li><a class="download" href="downloads.html">download</a></li>
<li class="btn-contact"><a class="contact" href="contactus.php">contact</a></li>
</ul>
</div>
<span class="text-looking">LOOKING BIG MAKES ALL THE DIFFERENCE</span>
</div>
<!--header end
container start-->
<div id="container">
<!--double-block-->
<div class="double-block">
<div class="top-block">
<div class="top">
<div class="bottom title-block">
<!--title-block-visual-->
<img class="title-block-visual" src="images/pic1.jpg" alt="image"/>
<div class="text-box">
<h1 class="look-big">LOOK BIG!</h1>
<p>PufferFish Communications will negotiate your voice and data contracts for free, provide you with quotes from multiple leading providers, and do it all in a few short days.
</p>
</div>
</div>
</div>
</div>
<div class="botom-block">
<div class="block-content">
<span class="arrow-down">&nbsp;</span>
<span class="text-take-action">TAKE ACTION: CALL US NOW FOR A FREE EVALUATION 1-888-766-9591</span>
</div>
<div class="bottom"></div>
</div>
</div>
<!--inner-block-->
<div class="inner-block sep-line">
<div class="top">
<div class="columns-holder">
<div class="column1">
<h2 class="tired-of">Tired of being treated like a small fish?</h2>
<p>Wish you could “puff up” when needed? Welcome to PufferFish. We negotiate voice and data contracts on your behalf - for free! Call us at 888-766-9591 or fill out the form below. We’ll present you with multiple quotes; you choose the plan that best fits your needs.<br />
<br />
</p>
</div>
<div class="visual-column">
<div class="text">
<h2 class="hello-pufferfish">Hello, PufferFish</h2>
<p class="text-can-someone2-landing">Can someone tell me why I pay so much for voice and data communications and my website looks looks like it was made in someone's garage?</p>
</div>
<!--visual-->
<img class="visual" src="images/pic2.gif" alt="image"/>
</div>
<div class="download-pdf">
<strong>Download</strong>
<a href="downloads/PufferFish-New-Services-Brochure.pdf" target="_blank">PDF</a>
</div>
</div>
</div>
</div>
</div>
<div class="landing-form">
<div class="landing-form-top">
<div class="landing-form-bot">
<div class="contact-info">
<div class="contact-info-top">
<div class="contact-info-bot">
<h3>Who are you?</h3>
<form action="post">
<fieldset>
<div class="row">
<div>
<label class="contact" for="contact">Contact</label>
<input name="Name" type="text" id="contact" />
</div>
<div>
<label class="business-name" for="business-name">Business Name</label>
<input name="BizName" type="text" id="business-name" />
</div>
</div>
<div class="row">
<div>
<label class="email-contact" for="email-contact">Email Contact</label>
<input id="email-contact" type="text" />
</div>
<div>
<label class="phone-contact" for="phone-contact">Phone Contact</label>
<input id="phone-contact" type="text" />
</div>
</div>
<div class="row">
<strong>Contact Me Via</strong>
<ul>
<li>
<input id="phone" type="checkbox" />
<label for="phone">Phone</label>
</li>
<li>
<input id="email" type="checkbox" />
<label for="email">Email</label>
</li>
<li>
<input id="either" type="checkbox" />
<label for="either">Either</label>
</li>
</ul>
</div>
</fieldset>
</form>
</div>
</div>
</div>
<div class="needs-box">
<h3>Needs</h3>
<p>Please check the boxes and provide comments that are applicable for your needs.</p>
<form action="#">
<fieldset>
<div class="voice">
<input id="voice" type="checkbox" />
<label for="voice">FREE Voice and Data Analysis (Yes, Free)</label>
</div>
<ul>
<li>
<input id="internet" type="checkbox" />
<label for="internet">Internet</label>
</li>
<li>
<input id="phone2" type="checkbox" />
<label for="phone2">Phone</label>
</li>
<li>
<input id="collaboration" type="checkbox" />
<label for="collaboration">Collaboration</label>
</li>
</ul>
<ul class="other">
<li>
<input id="telecom" type="checkbox" />
<label for="telecom">Telecom Expense Management</label>
</li>
<li>
<input id="conferencing" type="checkbox" />
<label for="conferencing">Conferencing</label>
</li>
<li>
<input id="telecom2" type="checkbox" />
<label for="telecom2">Telecom Disaster Recovery</label>
</li>
</ul>
<div class="comments">
<label for="comments">Comments</label>
<textarea id="comments" cols="20" rows="4"></textarea>
</span> </div>
</fieldset><input name="submit" type="image" class="btn-send-this" id="submit" src="images/btn-send-this.gif" align="right"/>
</form>
</div>
</div>
</div>
</div>
</div>
<!--container end
footer start-->
<div id="footer">
<!--footer-nav-->
<ul class="footer-nav">
<li><a href="index.html">home</a></li>
<li><a href="company.html">about us</a></li>
<li><a href="big-picture.html">what we do</a></li>
<li><a href="voice-data.html">voice - data</a></li>
<li><a href="design.html">web site design</a></li>
<li><a href="downloads.html" target="_blank">brochure download</a></li>
<li><a href="contactus.php">contact</a></li>
</ul>
<strong class="footer-logo"><a href="#">HuddleUp</a></strong>
</div>
<!--footer end-->
</div>
<!--main end-->
</div>
</div>
</div>
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
document.write(unescape("%3Cscript src='plugins/" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
</script>
try{
var pageTracker = _gat._getTracker("UA-10118767-1");
pageTracker._trackPageview();
} catch(err) {}</script>
<!--Begin Salesforce Tracking Code, Place immediately before closing tag-->
<script src=”sfga.js” type=”text/javascript”></script>
<script type=”text/javascript”>__sfga();</script>
<!--End Salesforce Tracking Code, Place immediately before closing tag-->
</body>
</html>
mikal83632
help
Please what am i doing wrong. Maybe something about setting up the page. I see the movie but dont have a few options I see.
NEED HELP ASAP please I need to get this form working.
Any help appreciated.
mikal83632
JavaScript Errors Now
ERROR:
"While executing GerateDynamicSourceBinding in WA_forms.htm a JavaScript error has occurred."
This happens when I click on anything in form and outside once this message starts. Started when I started eding from UVM edit Form.
Any help please - or support so I can finish
mikal83632
help help help
MY RESULTS AFTER UPLOAD is NOTHING HAPPENS: PufferLandingPage.php
I wish some support here please...
Lon WintersBeta Tester
This happened to me on ASP as well. I blamed it on the webhost, Network Sol, as other hosts didn't have a problem with it. They also wouldn't send unless the sender email address was in the same domain, that was using CDOSYS.
