getEncrypt not working with latest release of mySQLi extension
Thread begun 2/13/2021 1:47 pm by LionsMane | Last modified 2/14/2021 10:15 am by Ray Borduin | 2117 views | 6 replies |
LionsMane
WE had a custom session where you wrote some getEncrypt and getDecrypt for my sites, and I'm building a new one using the latest release of your extension (1.0.8), and now the getEncrypt function throws a 500 server error. We may need to do another screen share - I'm under a time restraint on this one. Thanks
LionsMane
Sample code atttached
Trying to use the login user behavior... edited with the getEncryptedVal we've used in the past. Code enclosed in PM.
Do you have an old copy of the queryobj.php file we created?
You could probably find the getEncryptedVal function in it and copy it to the new file.
LionsMane
Yes, it's alread in there
This from the queryobj being used:
public function getEncryptedVal($val) {
$retVal = $val;
$salt = "";
if ($this->Salt) $salt = base64_decode($this->Salt);
if ($retVal !== "") {
$retVal = base64_encode(openssl_encrypt($val,$this->EncryptionAlgorithm,$this->EncryptionKey, OPENSSL_RAW_DATA, $salt));
return $retVal;
I'd have to debug this. If you want to give me a call I can do screen sharing with you.
LionsMane
added the statement - didn't help
I added this per our conversation, but I'm still getting the error. Maybe I missed something?
if (isset($_POST["Submit"]) || isset($_POST["Submit_x"])) {
$UpdateQuery = new WA_MySQLi_Query($webcast);
LionsMane
Fixed it
I removed the submit check to just make it a simple declaration and now it all works. Thanks for your patience.
