Confirmation page error: no gateway.php
Thread begun 2/24/2021 2:30 pm by Peterson Design Studio - jefferis | Last modified 2/25/2021 12:38 pm by Ray Borduin | 2678 views | 7 replies |
Fatal error: require_once(): Failed opening required 'webassist/ecart/checkout/credentials/gateways.php' (include_path='.:/usr/local/lib/php') in /usr/home/dealerssupply/public_html/dealerssupplyco.com/confirm.php on line 2
When I created the eCart I chose no gateway because the client only wants the order list and doesn't process online. This file does not exist in the folder mentioned.
Any ideas?
You can just delete the reference to that file since you aren't using a gateway.
if you look in the attached file for checkout, there is no reference to gateway.php. When I open the server behaviors I don't see one there either.
It is probably on confirm.php
Okay, that got me through to the checkout. It was on confirm. I filled in the name info on the cart and hit Continue, but it stalls out at that point just showing the loading graphic. Also, and this is minor, but the thumbnail item loses the path to the image. Don't see a code where I can add "images/products" to it. However if I just hit submit, it will process, but it doesn't seem to send a confirmation email
You had a redirect in your store cart summary in database server behavior that was causing the page to redirect before sending the email.
I've fixed the confirm.php page. There was also an older version of webassist/framework/javascript/ajax.js that I updated to the latest version to fix the checkout page waiting message.
Please download those two pages to make sure you don't overwrite my fixes.
thanks ray. should I redownload the ecart plugin to fix this for the future?
Yes. Reinstalling should fix it in the future.
