Forgotten password wrong url
Thread began 3/11/2021 4:39 am by Sweens | Last modified 3/13/2021 11:20 am by Ray Borduin | 793 views | 11 replies |
Sweens
Hi Ray
Having an issue with the forgotten password process. On some emails, a full stop is at the end of the url e.g. ...com&fp_data=inTMao6O9Tpm.
In the link in the paragraph 'password update' the url is correct, including the full stop at the end - but the full url that can be copied and pasted does not contain the full stop, so an error is returned.
I'll post an example in the private field.
Cheers
Chris
You should be able to adjust the page that sends the code to remove periods from the list of available strings when creating the link. If you attach the page I can show what line number needs to be adjusted.
Sweens
Thanks Ray - file attached.
Cheers
Chris
Can I get FTP access? I need to look at the email body and return pages and it will be easier to do with full access to the server for testing.
Sweens
see PM
I updated the file: webassist/security_assist/helper_php.php and made it encode the period. That should fix the problem.
Sweens
Many thanks Ray
Cheers
Chris
Sweens
Hi Ray
Unfortunately, it has stripped the . from url's etc, so when the link in the text is clicked, the address fails.
It's only the full stop in the fp_data parameter that needs to be stripped.
When I try my address, both links work fine, but my colleague's address in the pm still always returns the full stop at the end of the url. Is it possible to sett the fp_data so that full stops are not used?
Cheers
Chris
It appears to work for me with the link you provided. What browser are you using?
Sweens
Hi Ray
Using Chrome and Firefox I get the error:
Notice: Undefined index: random_question in /home/sites/12b/8/8584b72192/public_html/forgottenpassword.php on line 287
Cgeers
Chris
