Focus Color not activating
Thread begun 3/22/2021 6:24 am by birdscreen398247 | Last modified 3/24/2021 12:12 pm by Ray Borduin | 1839 views | 5 replies |
birdscreen398247
DataBridge, Form Builder
I set a different background color for when a test field gets focus, but it isn't working.
I did this in the Preset Manager.
It stays the same color as the initial state.
How do I force this to take effect?
Can you send a url of the page where you are doing this? I'll take a look and see what is wrong.
birdscreen398247
This page is still under construction, but it shows the problem.
https://pabirds.org/porc/PORC_RareBirdReportInputForm.php
It looks like the focus color wasn't added to the css. It can be added manually pretty easily like:
form.PORC_PORC input.formTextfield_Large:focus, form.PORC_PORC input.formTextfield_Medium:focus, form.PORC_PORC input.formTextfield_Small:focus {
background-color:red;
birdscreen398247
I had set the focus color in the Form Edit Design module (see attached screenshot).
So why didn't it take?
Why do I have to do it manually?
I entered the code you suggested, but ut still doesn't work. (See attached css file)
The form builder css was referencing Spry classes that are no longer used.
I have fixed it in the extension. If you download and install the latest version, it should create the correct code now.
